09-01-2011, 23:20 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | BAK-MP203WF no repair three imei MODEL IS BAK= BAK-MP203WF Action: read/check information Model: _Autodetect MT6228-6268 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6235, E04 Hardware version: PX Software version: TL_GG950PU823_F28LI0 Software date: 2000.00.00 Barcode: MT012345678901234567 imei-1: 3XXXX0036869463 imei-2: 3XXXX0036961260 imei-3: 3XXXX0036869463 Finished, time used: 15 sec Remove/Install battery now ! problem is freeze after format phone work but no repair three imei help-me |
09-01-2011, 23:34 | #2 (permalink) |
Member: 211017 Status: Offline Thanks Meter: 312 | after format: COM3 [VCP0] selected module v4.01 Device: _Autodetect MT6228-6268 NAND Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0053]: 00AD:00A100000015 [HYNIX] H8BCS0PG0MBP chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02800000/05800000 firmware size: 40Mb ffs size: 88Mb detect sec ro... detect custom parameters... detect project-id... project-id: TL_GG950PU823_F28LI0A_00.98 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: TELACOM35_08B_PMWY_BOOTLOADER_V005_MT6235B_TL_GG95 0PU823_F28LI0A nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: TELACOM35_08B_PMWY_PCB01_GPRS_MT6235B_S01.TL_GG950 PU823_F28LI0A_00_98.BIN project-id: TL_GG950PU823_F28LI0A_00.98, 00000000 code offset: 00000000 ffs offset/size [01]: 02800000/05800000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.4.01, database date: 19.08.2011): TELACOM35_08B_PMWY_PCB01_GPRS_MT6235B_S01.TL_GG950 PU823_F28LI0A_00_98.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== warning: can not format: HW_STORAGE_NOR is not present Format... autodetection mode... Format done Disconnect... done Finished, time used: 1 min 16 sec Remove/Install battery now ! Action: read/check information Model: _Autodetect MT6228-6268 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6235, E04 Hardware version: PX Software version: TL_GG950PU823_F28LI0 Software date: 2000.00.00 Barcode: MT012345678901234567 imei-1: " imei-2: " imei-3: " Finished, time used: 25 sec Remove/Install battery now ! Action: "repair imei" Model: _Autodetect MT6228-6268 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: " imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 3XXXXX036869463 verification Ok Finished, time used: 3 sec Remove/Install battery now ! Action: "repair imei" Model: _Autodetect MT6228-6268 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-2: " imei write method: mode-1 imei write channel: imei #2 for dual sim/mono CPU new imei-2: 3XXXXX036961260 verification Ok Finished, time used: 3 sec Remove/Install battery now ! for three sim: Use only for mode-3 ! I select mode-3 but information is: method is not supported yet |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
