04-27-2009, 11:30 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Hong Kong
Member: 460857 Status: Offline Thanks Meter: 804 | ********* Big problem of XKSSTEL china phone******* I have lot of XKSSTEL same problem format after dead i am try to flash but same problem File info : UNISTAR25_GEMINI_PCB01_GPRS_MT6225_S00.X_S3_4524_V 1_8_0924.BIN please help infinity team. |
04-27-2009, 21:43 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! try to write both files: [bin] flashfiles/ChineseMiracle/_MT6225/eeprom/UNISTAR25_GEMINI_PCB01_GPRS_MT6225_S00.X_S3_4524_V 1_8_0924__ffs_017.B0E.bin [bin] flashfiles/ChineseMiracle/_MT6225/UNISTAR25_GEMINI_PCB01_GPRS_MT6225_S00.X_S3_4524_V 1_8_0924__XKSSTEL-S4_16m_En_Ru_Fr_Es_Id_Th_Vn_Tr_Farsi_Pt_Ar.B0M.bin and make sure battery voltage is OK |
04-28-2009, 09:55 | #4 (permalink) | |
Member: 460857 Status: Offline Thanks Meter: 804 | Quote:
i am allrady try to flash & eeprom . but same problem dead | |
04-28-2009, 10:58 | #5 (permalink) |
Member: 460857 Status: Offline Thanks Meter: 804 | COM11 [VCP0] selected module v2.81 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:3403:0008 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: UNISTAR25_GEMINI_PCB01_GPRS_MT6225_S00.X_S3_4524_V 1_8_0924.BIN ver. sw 2: X_S3_4524_V1.8_0924, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: UNISTAR25_GEMINI_PCB01_GPRS_MT6225_S00.X_S3_4524_V 1_8_0924__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\UNISTAR25_GEMINI_ PCB01_GPRS_MT6225_S00.X_S3_4524_V1_8_0924__ffs_200 90428-155434.B0E.bin flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Area: Eeprom/ffs flash: EC257E25082501:18E59F00000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . detect device identification#2 finished Write Done Finalization ... Finalization Done Finished, time used: 145 sec Remove/Install battery now ! |
04-28-2009, 20:16 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i can see only one reason for this: our support area file is damaged. sometimes poeple send us flash files from dead phones. can you find same working phone with firmware UNISTAR25_GEMINI_PCB01_GPRS_MT6225_S00.X_S3_4524_V 1_8_0924 ? |
06-01-2009, 19:33 | #7 (permalink) |
Freak Poster Join Date: Jan 2007 Location: india
Member: 431754 Status: Offline Thanks Meter: 30 | XKSSTEL-S2 Need Falash File UNISTAR25_GEMINI_PCB01_GPRS_MT6225_S00.X_S3_TOSHIB A_V1_7_0922__flash_.B0M UNISTAR25_GEMINI_PCB01_GPRS_MT6225_S00.X_S3_TOSHIB A_V1_7_0922__ffs_.B0E thanks |
The Following 2 Users Say Thank You to ahmedzameer For This Useful Post: |
I have big probleme of sony erricsson k750 worlds big prob..... | suraj9860607689 | Nokia Hardware & Hardware Repair | 7 | 04-08-2009 05:59 |
i have very big problem with 2 china phone | SHIJILFONOTLY | Infinity-Box | 7 | 05-28-2008 14:08 |
the big problem of d750 flash to k750,the phone can't open | zyairsnow | HWK | 0 | 09-19-2005 12:43 |
Big Problem of Mmcs ? | the_frightener | Nokia Multimedia | 7 | 11-04-2004 22:39 |
Big problem of Sagem Switcher | hitibiti | ARM9 BASED M62 / M62+ | 2 | 05-15-2004 13:17 |
