Old 03-29-2009, 17:22   #1 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Can i recover this china phone
Hello,
I got dead china set. I try to clean the complete board in Elma.
After that phone take info from Chinies Miracle V.79
I try to read detailed info but it show this.......
COM15 [VCP1] selected
module  v2.79
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read/check detailed information
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:0B03:0003
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:FFFFFF00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
Warning: probably flash chip is empty, erased, incorrectly flashed or damaged !
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detecting ffs/eeprom structure pass 1...
detect standard fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs/eeprom detected ok: element #1
detecting ffs/eeprom structure pass 2...
ffs/eeprom detected ok element #2
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Finished, time used: 157 sec
Remove/Install battery now !
Also i don't know what is the model (Coz back side of phone no Lable also in front of the phone No any brand name OR etc....). Also don't know what is the software version of this set ...
Old 03-29-2009, 21:18   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
try to heat flash IC. maybe bad soldering is reason for such behavior.
if this will not help- post phone picture, maybe someone recognize it
Old 03-30-2009, 16:53   #3 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Here is the Picture of the set.
Old 04-01-2009, 17:40   #4 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
picture is posted but not any reply yet.......
Old 04-02-2009, 23:35   #5 (permalink)
Member: 148515
hello!
i dont recognize it, maybe some other forum member will do
can i recover this v3i error with ph sig err:35.02 aikonmani Smart-Clip 2 03-17-2009 15:14
problem with this china phone alfox Infinity-Box 4 09-14-2008 22:06
problem with this china phone V9+i alfox Infinity-Box 3 09-13-2008 06:26
"Help Me" to flash this china phone piratekhan2 Chinese Models & Cloned Phones 1 07-04-2008 06:08
pls, any help for this china phone ballybaka Phone Unlocking Codes & Maps 1 12-19-2007 09:19
Page generated in 0.19293 seconds with 10 queries
