07-27-2010, 21:27 | #1 (permalink) |
Freak Poster Join Date: Jun 2004 Age: 41
Member: 67632 Status: Offline Thanks Meter: 37 | Can not repair China K999 I have the next problem with phone same like this K999 I read backup from this phone, but when i try flash it back i have the next message that unknown firmware detect, after press ok the hext message was You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? And if press ok, phone flashing, but no power on. Here is the log: Code: COM5 selected module v3.19 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash write: Firmware TET26_07B_PCB01_GPRS_MT6226_S01.P538_CM_AMD_1_1_0_TB1R3C2K1_26B__fullflash_20100727-210138.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:FD41:687D status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [protected] type, 1 record(s) TCL-ID is absent startup code area #1 record #1 is damaged, recalculation required rom info detection finished device-id: CDFD0B54 rom info ver: 04 sw version: TET26_07B_PCB01_GPRS_MT6226_S01.P538_CM_AMD_1_1_0_TB1R3C2K1_26B.BIN project-id: P538_CM_AMD_1.1.0_TB1R3C2K1_26B, 39889A75 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [protected] type, 1 record(s) TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... rpl file not found: E:\Program Files\InfinityBox\ChineseMiracle\id.CDFD0B54.[TET26_07B_PCB01_GPRS_MT6226_S01.P538_CM_AMD_1_1_0_TB1R3C2K1_26B.BIN_759A8839].rpl rpl file not found: E:\Program Files\InfinityBox\ChineseMiracle\id.CDFD0B54._TET26_07B_PCB01_GPRS_MT6226_S01.P538_CM_AMD_1_1_0_TB1R3C2K1_26B.BIN_759A8839_.rpl rpl file not found: E:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.CDFD0B54.[TET26_07B_PCB01_GPRS_MT6226_S01.P538_CM_AMD_1_1_0_TB1R3C2K1_26B.BIN_759A8839].rpl rpl file not found: E:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.CDFD0B54._TET26_07B_PCB01_GPRS_MT6226_S01.P538_CM_AMD_1_1_0_TB1R3C2K1_26B.BIN_759A8839_.rpl ==================== warning: unknown rom info structure: TET26_07B_PCB01_GPRS_MT6226_S01.P538_CM_AMD_1_1_0_TB1R3C2K1_26B.BIN_759A8839 Unknown firmware detected (v.3.19, database date: 16.07.2010), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: TET26_07B_PCB01_GPRS_MT6226_S01.P538_CM_AMD_1_1_0_TB1R3C2K1_26B.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed detecting startup code area #2... startup code area #2 is absent You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? aborted by user Write Fail Finished, time used: 3 min 27 sec Remove/Install battery now ! RapidShare: 1-CLICK Web hosting - Easy Filehosting |
07-29-2010, 08:39 | #3 (permalink) |
Member: 67632 Status: Offline Thanks Meter: 37 | Phone is the same. I readed from one, working and write to other, but this two phones are same. And one of them will be working, but when i try flash one of the firmware from support TET26_07B_PCB01_GPRS_MT6226_S01.P18A_SC_AMD_0_0_6_ TC2K1_26B_16m_En_Cn.B0M.bin, phone power on after this, but LCD is not working. |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
