05-25-2010, 08:28 | #1 (permalink) |
No Life Poster Join Date: Aug 2002 Location: BULGARIA Age: 53
Member: 14868 Status: Offline Thanks Meter: 44 | Can not write backup on MT6235B Model: H802, like W007. Phone freeze after 30 sec. after power-on, so i readed back-up first. after trying to write other firmware from support- > fail. Write back-up - fail again, all speeds tested - fail. here is the log: ------------------------ COM7 [VCP0] selected module v3.13 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: write flash NAND write: Firmware E710_KLX1HVGA_PCB01_GPRS_MT6235B_S01.01_0__firmwar e_20100521-161353.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: E710_BOOTLOADER_V005_MT6235B_01_1.bin nfi area detection finished: Ok "format ffs" active interface: BROM_DLL_v3.952.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0058]: 002C:00A100800095 [MICRON] MT29F1G08ABB chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 03000000/05000000 firmware size: 48Mb ffs size: 80Mb detect sec ro... detect custom parameters... detect project-id... project-id: E710_KLX1HVGA.01.0 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: E710_BOOTLOADER_V005_MT6235B_01_1.bin warning: id-page1 area is invalid nfi area detection finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 05 sw version: E710_KLX1HVGA_PCB01_GPRS_MT6235B_S01.01_0.BIN project-id: E710_KLX1HVGA.01.0, 00000000 code offset: 00000000 ffs offset/size [01]: 03000000/05000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done ==================== New firmware detected (v.3.13, database date: 25.04.2010): E710_KLX1HVGA_PCB01_GPRS_MT6235B_S01.01_0.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== nfi area detection... external bootloader is not present bootloader version: E710_BOOTLOADER_V005_MT6235B_01_1.bin nfi area detection finished: Ok startup code area #1 check... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... error: can not write flash: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL error: last error: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL Disconnect... done Finished, time used: 4 min 9 sec Remove/Install battery now ! Device: Autodetect 6228-6229 NOR -------------------------------------------------- here is the backup from phone: RapidShare: 1-CLICK Web hosting - Easy Filehosting Any help is welcome, phone is dead for now ahhhh and customer w8. WBR |
05-25-2010, 14:28 | #2 (permalink) |
No Life Poster Join Date: Aug 2006 Location: P@kIsTaN
Member: 327384 Status: Offline Sonork: 100.1605419 Thanks Meter: 312 | Hello here is also same problem i have with MFU E71......... COM3 [VCP0] selected module v3.13 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: write flash NAND write: Firmware TELACOM35_08B_PMWY_PCB01_GPRS_MT6235B_S01.TL_T7135 P3U241_F28L21A_00_63__firmware_20100514-195144.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: TELACOM35_08B_PMWY_BOOTLOADER_V005_MT6235B_TL_T713 5P3U241_F28L21 nfi area detection finished: Ok interface: BROM_DLL_v3.952.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0053]: 00AD:00A100000015 [HYNIX] H8BCS0PG0MBP chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 05000000/03000000 firmware size: 80Mb ffs size: 48Mb detect sec ro... detect custom parameters... detect project-id... project-id: TL_T7135P3U241_F28L21A_00.63 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: TELACOM35_08B_PMWY_BOOTLOADER_V005_MT6235B_TL_T713 5P3U241_F28L21 nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: TELACOM35_08B_PMWY_PCB01_GPRS_MT6235B_S01.TL_T7135 P3U241_F28L21A_00_63.BIN project-id: TL_T7135P3U241_F28L21A_00.63, 00000000 code offset: 00000000 ffs offset/size [01]: 05000000/03000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done ==================== New firmware detected (v.3.13, database date: 25.04.2010): TELACOM35_08B_PMWY_PCB01_GPRS_MT6235B_S01.TL_T7135 P3U241_F28L21A_00_63.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected]or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== nfi area detection... bootloader version: TELACOM35_08B_PMWY_BOOTLOADER_V005_MT6235B_TL_T713 5P3U241_F28L21 nfi area detection finished: Ok startup code area #1 check... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... error: can not write flash: 0BBF:S_DA_RAM_ERROR error: last error: 0BBF:S_DA_RAM_ERROR Disconnect... done Finished, time used: 1 min 37 sec Remove/Install battery now ! |
05-26-2010, 00:58 | #3 (permalink) | |
05-26-2010, 01:00 | #4 (permalink) | |
I am not sure, but if phone was with "freez" problem before and can not be flashed well - it looks like HW problem (bad soldered or damaged NAND flash chip, bad soldered CPU). | |
05-26-2010, 08:25 | #5 (permalink) |
Member: 14868 Status: Offline Thanks Meter: 44 | I will wait a bit, before HW repair. If there are more complains from flash write on such platform. Could be little bug, or any buffer overflow, because flashwrite stops at different addresses. at 2 - 3 % from the begin. If stops at same address this is HW, but if at different - not sure. WBR |
06-01-2010, 15:58 | #11 (permalink) |
Member: 14868 Status: Offline Thanks Meter: 44 | Well, i made Format "Whole Flash Chip". After try to write fullflash and result is the same Failed. COM7 [VCP5] selected module v3.14 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: write flash NAND write: Firmware E710_KLX1HVGA_PCB01_GPRS_MT6235B_S01.01_0__firmwar e_20100521-161353.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: E710_BOOTLOADER_V005_MT6235B_01_1.bin nfi area detection finished: Ok interface: BROM_DLL_v3.952.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0058]: 002C:00A100800095 [MICRON] MT29F1G08ABB chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 03000000/05000000 firmware size: 48Mb ffs size: 80Mb detect sec ro... detect custom parameters... detect project-id... project-id: E710_KLX1HVGA.01.0 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: E710_BOOTLOADER_V005_MT6235B_01_1.bin warning: id-page1 area is invalid nfi area detection finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 05 sw version: E710_KLX1HVGA_PCB01_GPRS_MT6235B_S01.01_0.BIN project-id: E710_KLX1HVGA.01.0, 00000000 code offset: 00000000 ffs offset/size [01]: 03000000/05000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done nfi area detection... external bootloader is not present bootloader version: E710_BOOTLOADER_V005_MT6235B_01_1.bin nfi area detection finished: Ok startup code area #1 check... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... error: can not write flash: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL error: last error: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL Disconnect... done Finished, time used: 1 min 53 sec Remove/Install battery now ! |
07-09-2010, 15:49 | #13 (permalink) |
Registered User Join Date: Feb 2008 Location: São paulo - Brasil
Member: 715511 Status: Offline Thanks Meter: 12 | Same problem... That's log: COM7 [VCP0] selected module v3.15 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: write flash NAND write: Firmware L029_ML_PCB01_GPRS_MT6235B_S01.L029_ML_TY8_WF_GPS_ TV_MT6601_V4_03_128m_En_Ru_Gr_Nl_Es_It_Pl_De_Ml_Id _Th_Vn_Cn_Pt_Bg_Cz.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: L029_ML_BOOTLOADER_V005_MT6235B_L029_ML_TY8_WF_GPS _TV_MT6601_V4_ nfi area detection finished: Ok interface: BROM_DLL_v3.1012.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00D100900015 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done nfi area detection... bootloader version: L029_ML_BOOTLOADER_V005_MT6235B_L029_ML_TY8_WF_GPS _TV_MT6601_V4_ nfi area detection finished: Ok startup code area #1 check... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... <<< (At this momment it stop in 15%) Disconnect... done Finished, time used: 2 min 31 sec Remove/Install battery now ! (That's stop on 15%, always, with all the firmware of the support, and with the backup too, now the phone is dead...) PLS, Help us! |
07-09-2010, 23:39 | #14 (permalink) | |
Major Poster Join Date: Feb 2007 Location: MAKASSAR
Member: 456749 Status: Offline Thanks Meter: 7 | hello Quote:
infinity cannot suport cpu 6235b...dont try again!!! | |
07-22-2010, 19:49 | #15 (permalink) |
Member: 715511 Status: Offline Thanks Meter: 12 | Nothing solved yet... Tried to update to the newest version 3.19, but the problem still the same... Log: COM7 [VCP0] selected module v3.19 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: write flash NAND write: Firmware L029_ML_PCB01_GPRS_MT6235B_S01.L029_ML_TY8_WF_GPS_ TV_MT6601_V4_03_128m_En_Ru_Gr_Nl_Es_It_Pl_De_Ml_Id _Th_Vn_Cn_Pt_Bg_Cz.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: L029_ML_BOOTLOADER_V005_MT6235B_L029_ML_TY8_WF_GPS _TV_MT6601_V4_ nfi area detection finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00D100900015 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: L029_ML_TY8_WF_GPS_TV_MT6601_V4.03 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: L029_ML_BOOTLOADER_V005_MT6235B_L029_ML_TY8_WF_GPS _TV_MT6601_V4_ warning: id-page1 area is invalid nfi area detection finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: L029_ML_PCB01_GPRS_MT6235B_S01.L029_ML_TY8_WF_GPS_ TV_MT6601_V4_03.BIN project-id: L029_ML_TY8_WF_GPS_TV_MT6601_V4.03, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: 2nd [standard] type TCL-ID is absent ===> done nfi area detection... bootloader version: L029_ML_BOOTLOADER_V005_MT6235B_L029_ML_TY8_WF_GPS _TV_MT6601_V4_ nfi area detection finished: Ok startup code area #1 check... error: done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . . . . write core... Disconnect... done Finished, time used: 4 min 45 sec Remove/Install battery now ! (tried: NOR bootcode old and new style, another speed, auto bootspeed, check and uncheck all combination of the settings, but the problem still... plz solve our problem) Thx anyway! |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
