Old 12-30-2008, 13:20   #1 (permalink)
sidramobilecare's Avatar
Member: 888557
Sonork: 100.1608317
Thanks Meter: 34
Can't initialize test mode
HI
China tv Pda starts but it does not go beyond calibrate screen,
While doing a touchscreen calibration infinity box gives the following error
COM31 [Serial2] selected
Action: touchscreen calibration
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
error: boot phase#2/1 failed
Can't initialize test mode !
Possible reasons:
1. communication fault, repeat required operation
2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method
error: operation failed !
Finished, time used: 47 sec
Remove/Install battery now !
Please help
Old 12-30-2008, 16:16   #2 (permalink)
.::BHATTI::.'s Avatar
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
it lookd like the cable problem .............. u need to chek the connection again ...........
Old 12-30-2008, 18:50   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
yes, this is wrong cable problem
Old 02-17-2009, 13:05   #4 (permalink)
Nadjombe's Avatar
Member: 185608
Thanks Meter: 592
Lightbulb Can't initialize test mode
You will realise that there's a kind of mobiles that can't be connected even pins solde on the pcb.
I can accept the second reson of box message(cpu damage).
But why a kind of mobiles and what's real solution?
Old 02-18-2009, 15:42   #5 (permalink)
Member: 148515
hello!
solution for error message which was posted above is only one: find good pinout and assemble good cable
6280 can't enter test mode for unlocking Cake BB5 Box by D.K. 5 03-16-2008 02:44
E50, can't get test mode to unlock.. chmielu_gsm MT-BOX 5 11-07-2007 13:20
T400 can't enter test mode!! eddierasta VLSI, Conexant, Skyworks and Old Models 0 08-02-2005 17:55
Blazer can't enter test mode LG8120 v101 jusluke Blazer 4 03-22-2005 05:41
Mars MT050 problem: Phone locked.... can't enter Test Mode mourad_t Mitsubishi 2 09-23-2003 18:28
Page generated in 0.22066 seconds with 10 queries
