12-06-2008, 12:44 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Timeless zone! Age: 35
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 162 | Cant Read or Remove User lock on the phone! I have Sunrise t868 phone with MT6226 chip in it.....I want to remove or read the user code of this phone but no successs yet!............I have used all unlocking methods which avail....Even formatted phone in safe and complete mode!...But still same....So wht i have to do for solve this problem! here is log from infinty! COM17 [VCP0] selected module v2.69 Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:F9E6:AC1B Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: M858DFX_6226b_MULTI_11H Version: M858_01 detecting structure #2... 0 done 44 byte(s) read imei: 1---------------- warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #1... 0 3 4 5 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29error: detection failed (27 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 107 sec Remove/Install battery now ! waiting for the answer! |
12-06-2008, 15:13 | #4 (permalink) |
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 162 | Tried each and every code avail....But still same...... Another strange thing is when i enter code and press ok button after that i can hear the sound of keypad but button not working.......But cursor and sms sign is still blinking....So whats the problem! |
12-07-2008, 11:58 | #8 (permalink) | |
In most cases default code is 1122. Do you know what is this phone history ? Probably phone was flashed already before and it may be that it was flashed with incorrect firmware. Can you check what is this phone history ? | |
12-08-2008, 09:15 | #9 (permalink) | |
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 162 | Quote:
Yes i have tried all default codes but still same! As far as firmware concern customer told me that once the phone having restart problem and formatted the phone once!After that phone working well....Now he just locked the phone and forgot the password and i tried all avail options in infinity but still same........... | |
12-09-2008, 09:30 | #14 (permalink) | |
Just make format ffs in "complete" mode. If user code was set by user this operation should reset user code to it's default values. | |
12-12-2008, 07:43 | #15 (permalink) | |
Sent on infintyhelp#yahoo.com.hk Subject....Fulflash backup for removing user code of phone! my mailingg address is muneebakhtar#gmail.com Thanks for suggestion but if u read my first post carefully then u will came to know that is already did it! Thanks for the reply i already did it but still same.....Yes i already done alot with this method but still same.....Tried all defualt codes....Amazing problem! | |
How to remove user lock on SH210 ? | ribbentrop | LG | 0 | 12-06-2009 15:42 |
How to read or remove user code of sony ericsson without flashing? | nofear99 | Sony Ericsson | 5 | 11-15-2009 07:41 |
How to read or reset user code on Alcatel C560a philips based phone? | DJiCE | Alcatel TCL Phones and New Models | 1 | 02-12-2008 03:24 |
Need to reset user lock on BH4 phones using Vygis How to do it?? | ReyTech | VygisToolbox | 7 | 06-26-2007 13:06 |
How read or remove user lock in T191 | brussl | Motorola ODM | 28 | 04-01-2002 13:04 |
