11-09-2008, 07:40 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Phils
Member: 331390 Status: Offline Thanks Meter: 434 | Can't repair "1600 Bad Software" I can't repair this 1600 shows Bad Software. Tried it many time w/ Repair Bad Software Button many times. Tried Format Safe and Complete Method. Flash it with backup FW and eeprom, but sad to say, it's still the same please help! Code: ==== log: [11/9/2008 1:26:55 PM] ==== COM7 [VCP2] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:8626:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 921600 error: wrong answer: C3 error: can't work at this speed, use lower speed Set baud Fail Finished, time used: 11 sec Remove/Install battery now ! ==== log: [11/9/2008 1:27:33 PM] ==== COM7 [VCP2] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... ==== log opened: [11/9/2008 1:28:02 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.exe Loading data, wait... [Infinity Box] v2.66 S/N: 1C2F:0111 Wait... Device: Autodetect 6205-6227 NOR Done ==== log: [11/9/2008 1:28:11 PM] ==== COM7 [VCP2] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! error: boot initialization step-3 failed: 00 error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 30 sec Remove/Install battery now ! ==== log: [11/9/2008 1:30:42 PM] ==== COM7 [VCP2] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 33 sec Remove/Install battery now ! ==== log: [11/9/2008 1:32:26 PM] ==== COM7 [VCP2] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 27 sec Remove/Install battery now ! ==== log: [11/9/2008 1:34:53 PM] ==== COM7 [VCP2] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! error: boot initialization step-3 failed: 00 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:8626:000C error: initialize step#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 9 sec Remove/Install battery now ! ==== log: [11/9/2008 1:35:10 PM] ==== COM7 [VCP2] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:8626:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN ver. sw2: N1112_V5.53, 00000000 ffs offset/size: 00700000/00100000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00700000 flash: EC257E25062501:2AEA0000000000 checking area[00000000]: 00000000-007FFFFF... eeprom/ffs found near: 00700000 detecting eeprom/ffs size... eeprom/ffs size: 00100000 ffs chip: 00 eeprom/ffs area: 00000000:00700000-007FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: flash[TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\flash[TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN]_20081109-134051.B0M.bin Finished, time used: 417 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [11/9/2008 1:42:30 PM] ==== COM7 [VCP2] selected module v2.66 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:8626:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2000.00.00 Version: 1.0 Version: N1112_V5.53 Version: detecting structure #2... 0 done 44 byte(s) read imei: 01146100445247 connection Ok building list... done items to clear: 121 121 of 121 items cleared building list... done 0 items remains Finished, time used: 22 sec Remove/Install battery now ! Imei 34500000000000 already was repaired: 10/25/2008-12:30:28 PM Continue with this imei ? Action: imei Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 9600 error: connection failed ! Operation failed ! Finished, time used: 11 sec Power off phone now ! Imei 34500000000000 already was repaired: 11/9/2008-1:44:24 PM Continue with this imei ? Action: imei Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 57600 error: connection failed ! Operation failed ! Finished, time used: 5 sec Power off phone now ! Imei 34500000000000 already was repaired: 11/9/2008-1:44:31 PM Continue with this imei ? ==== log: [11/9/2008 1:44:47 PM] ==== COM7 [VCP2] selected module v2.66 Action: imei imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 345000000000004 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect error: boot phase#2/1 failed Can't initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method error: operation failed ! Finished, time used: 9 sec Remove/Install battery now ! ==== log opened: [11/9/2008 2:29:39 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.exe Loading data, wait... [Infinity Box] v2.66 S/N: 1C2F:0111 Wait... Device: Autodetect 6205-6227 NOR Done ==== log: [11/9/2008 2:29:58 PM] ==== COM7 [VCP6] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: repair "bad software" (mode-2) Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:8626:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN ver. sw2: N1112_V5.53, 00000000 ffs offset/size: 00700000/00100000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting firmware protection... detecting firmware structure #8... phase #1... ................................ phase #2... ...................... done detecting firmware structure #9... detecting area #1... ....................... area #1 is found done detecting firmware protection done Finished, time used: 25 sec Remove/Install battery now ! ==== log: [11/9/2008 2:30:39 PM] ==== COM7 [VCP6] selected module v2.66 Action: repair "bad software" Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:8626:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2000.00.00 Version: 1.0 Version: N1112_V5.53 Version: detecting structure #2... 0 done 44 byte(s) read imei: 35935300337233 connection Ok detecting structure #6 (mode-1)... 0 done 181 byte(s) read writing data... verification... verification Ok Finished, time used: 17 sec Remove/Install battery now ! ==== log: [11/9/2008 2:34:48 PM] ==== COM7 [VCP6] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: repair "bad software" (mode-1) Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:8626:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN ver. sw2: N1112_V5.53, 00000000 ffs offset/size: 00700000/00100000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting firmware protection... detecting firmware structure #8... phase #1... ................................ phase #2... ...................... done detecting firmware structure #9... detecting area #1... ....................... area #1 is found done detecting firmware protection done Finished, time used: 52 sec Remove/Install battery now ! ==== log: [11/9/2008 2:35:44 PM] ==== COM7 [VCP6] selected module v2.66 Action: repair "bad software" Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:8626:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2000.00.00 Version: 1.0 Version: N1112_V5.53 Version: detecting structure #2... 0 done 44 byte(s) read imei: 35935300337233 connection Ok detecting structure #6 (mode-1)... 0 done 181 byte(s) read writing data... verification... verification Ok Finished, time used: 14 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [11/9/2008 2:36:53 PM] ==== COM7 [VCP6] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:8626:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN ver. sw2: N1112_V5.53, 00000000 ffs offset/size: 00700000/00100000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00700000 flash: EC257E25062501:2AEA0000000000 checking area[00000000]: 00000000-007FFFFF... eeprom/ffs found near: 00700000 detecting eeprom/ffs size... eeprom/ffs size: 00100000 ffs chip: 00 eeprom/ffs area: 00000000:00700000-007FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN]_20081109-143754.B0E.bin flash: EC257E25062501:2AEA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25062501:2AEA0000000000 Finalization Done Finished, time used: 68 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! ==== log: [11/9/2008 2:39:30 PM] ==== COM7 [VCP6] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: repair "bad software" (mode-1) Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:8626:000C error: initialize step#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 8 sec Remove/Install battery now ! ==== log: [11/9/2008 2:39:48 PM] ==== COM7 [VCP6] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: repair "bad software" (mode-1) Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: can't detect CPU id Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 6 sec Remove/Install battery now ! ==== log: [11/9/2008 2:40:15 PM] ==== COM7 [VCP6] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: repair "bad software" (mode-1) Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:8626:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN ver. sw2: N1112_V5.53, 00000000 ffs offset/size: 00700000/00100000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting firmware protection... detecting firmware structure #8... phase #1... ................................ phase #2... ...................... done detecting firmware structure #9... detecting area #1... ....................... area #1 is found done detecting firmware protection done Finished, time used: 24 sec Remove/Install battery now ! ==== log: [11/9/2008 2:40:43 PM] ==== COM7 [VCP6] selected module v2.66 Action: repair "bad software" Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:8626:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2000.00.00 Version: 1.0 Version: N1112_V5.53 Version: detecting structure #2... 0 done 44 byte(s) read imei: 35935300337233 connection Ok detecting structure #6 (mode-1)... 0 done 181 byte(s) read writing data... verification... verification Ok Finished, time used: 13 sec Remove/Install battery now ! ==== log: [11/9/2008 2:43:27 PM] ==== COM7 [VCP6] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: repair "bad software" (mode-2) Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:0000:0000 error: initialize step#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 13 sec Remove/Install battery now ! ==== log: [11/9/2008 2:43:48 PM] ==== COM7 [VCP6] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: repair "bad software" (mode-2) Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:8626:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN ver. sw2: N1112_V5.53, 00000000 ffs offset/size: 00700000/00100000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting firmware protection... detecting firmware structure #8... phase #1... ................................ phase #2... ...................... done detecting firmware structure #9... detecting area #1... ....................... area #1 is found done detecting firmware protection done Finished, time used: 25 sec Remove/Install battery now ! ==== log: [11/9/2008 2:44:17 PM] ==== COM7 [VCP6] selected module v2.66 Action: repair "bad software" Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:8626:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2000.00.00 Version: 1.0 Version: N1112_V5.53 Version: detecting structure #2... 0 done 44 byte(s) read imei: 35935300337233 connection Ok detecting structure #6 (mode-1)... 0 done 181 byte(s) read writing data... verification... verification Ok Finished, time used: 17 sec Remove/Install battery now ! Loading file v.02... flash[TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN]_20081109-134051.B0M.bin loaded identification#1 protocol ver: 04 ver. sw1: TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN ver. sw2: N1112_V5.53, 00000000 detecting languages... Languages: En Ru Fr Th Vn Cn Cn Loading file v.02... eeprom[TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN]_20081109-143754.B0E.bin loaded ==== log: [11/9/2008 2:45:37 PM] ==== COM7 [VCP6] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:8626:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN ver. sw2: N1112_V5.53, 00000000 ffs offset/size: 00700000/00100000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00700000 flash: EC257E25062501:2AEA0000000000 checking area[00000000]: 00000000-007FFFFF... eeprom/ffs found near: 00700000 detecting eeprom/ffs size... eeprom/ffs size: 00100000 ffs chip: 00 eeprom/ffs area: 00000000:00700000-007FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN]_20081109-144645.B0E.bin flash: EC257E25062501:2AEA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting security area (code #2)... security area (code #2) is absent Area: Firmware flash: EC257E25062501:2AEA0000000000 Write: Firmware Area: Eeprom/ffs flash: EC257E25062501:2AEA0000000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done Finished, time used: 154 sec Remove/Install battery now ! ==== log: [11/9/2008 2:48:52 PM] ==== COM7 [VCP6] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: repair "bad software" (mode-2) Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:8626:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN ver. sw2: N1112_V5.53, 00000000 ffs offset/size: 00700000/00100000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting firmware protection... detecting firmware structure #8... phase #1... ................................ phase #2... ...................... done detecting firmware structure #9... detecting area #1... ....................... area #1 is found done detecting firmware protection done Finished, time used: 25 sec Remove/Install battery now ! ==== log: [11/9/2008 2:49:20 PM] ==== COM7 [VCP6] selected module v2.66 Action: repair "bad software" Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:8626:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2000.00.00 Version: 1.0 Version: N1112_V5.53 Version: detecting structure #2... 0 done 44 byte(s) read imei: 35935300337233 connection Ok detecting structure #6 (mode-1)... 0 done 181 byte(s) read writing data... verification... verification Ok Finished, time used: 12 sec Remove/Install battery now ! ==== log: [11/9/2008 2:50:28 PM] ==== COM7 [VCP6] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: repair "bad software" (mode-1) Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:8626:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN ver. sw2: N1112_V5.53, 00000000 ffs offset/size: 00700000/00100000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting firmware protection... detecting firmware structure #8... phase #1... ................................ phase #2... ...................... done detecting firmware structure #9... detecting area #1... ....................... area #1 is found done detecting firmware protection done Finished, time used: 25 sec Remove/Install battery now ! ==== log: [11/9/2008 2:50:57 PM] ==== COM7 [VCP6] selected module v2.66 Action: repair "bad software" Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:8626:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2000.00.00 Version: 1.0 Version: N1112_V5.53 Version: detecting structure #2... 0 done 44 byte(s) read imei: 35935300337233 connection Ok detecting structure #6 (mode-1)... 0 done 181 byte(s) read writing data... verification... verification Ok Finished, time used: 14 sec Remove/Install battery now ! |
11-09-2008, 21:35 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if any of methods for reapiring Bad software is not work- read out full flash and send to [email protected] please write subject "Bad software reapir failed on atached firmware" |
## HOT ## Repair S3110 bad imei / No network / bad unlock | mrx3net | UST Pro II | 1 | 07-08-2009 21:52 |
wake up multi team ,,,,,,,infinity solved "LV918 Bad Software" problem | manish665 | Chinese Cocktail | 8 | 11-04-2007 12:47 |
bad p2k easy tool 5.3 can't repair v3 r374 pds | xiaoyuz | Motorola P2K (USB-Smart) | 0 | 08-18-2006 02:34 |
v3 r374 repair ok can't repair v3r r4515 | xiaoyuz | Motorola P2K (USB-Smart) | 0 | 06-20-2006 08:48 |
