03-05-2009, 12:55 | #1 (permalink) |
Freak Poster Join Date: Jan 2007 Location: Uk/Pk
Member: 436045 Status: Offline Sonork: 1581208 Thanks Meter: 31 | Cect 5300 Dead :( I attempted to COMPLETE format Cect E5300 and mistakenly i didnt safe backup for firmware and eeprom.. I found exact firmware on infinity support but i m having problem finding the exact eeprom.. I dont know how to find it i have all logs saved.. Plz help me tell me how to find eeprom.. br, TOm |
03-05-2009, 13:10 | #2 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
b.r.. | |
03-05-2009, 13:33 | #3 (permalink) |
Member: 436045 Status: Offline Sonork: 1581208 Thanks Meter: 31 | hmmm see the thing is its flashing all well but fone wont turn on... i tried safe format fone was ok it was on INSERT SIM after safe format it was aceepting sim but was on EMERGENCY.. i then did COMPELETE format it showed some EEPROM ADDRESS errror :S luckily i found both files on Support but fone is still dead here's the log when i performed Complete Format OM4 [VCP0] selected module v2.77 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:1703:0007 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.9A4B2838.[MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_116_0803 12.BIN_12B24DB9].rpl identification#1 detection finished device-id: 9A4B2838 identification#1 protocol ver: 04 ver. sw 1: MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_116_0803 12.BIN ver. sw 2: A521_L8EN_116_080312, 46B24DED ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs/eeprom size detection error: can't detect ffs/eeprom address/size Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: EC257E25082501:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_9A4B2838_MTK25_06B_PCB01_GPRS_MT6225_S00 .A521_L8EN_116_080312.BIN_12B24DB9_20090305-152423.B0X.bin Finished, time used: 49 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! br, |
03-05-2009, 13:55 | #4 (permalink) | |
MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_116_0803 12.BIN let me check... | |
03-05-2009, 14:03 | #5 (permalink) |
Member: 436045 Status: Offline Sonork: 1581208 Thanks Meter: 31 | Yeah bro i found it Flash file MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_116_0803 12_Nokia-5300-XpressMusic_16m_En_Ru_Fr_Id_Th_Vn_Farsi_Ar.B0M.bin eeprom MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_116_0803 12__ffs_01.B0E.bin Its flashing all well but still not turning on and i know it only happened coz of COMPLETE FORMAT br, |
03-05-2009, 14:15 | #6 (permalink) | |
yes.. ur flash file and eeprom r right..just an advice.. do again full complete format ffs then write eeprom and flash again..if not success at last do again complete format ffs.. | |
03-05-2009, 14:51 | #9 (permalink) | |
C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.9A4B2838.[MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_116_0803 12.BIN_12B24DB9].rpl good lucks.. | |
The Following User Says Thank You to LoveLess For This Useful Post: |
03-05-2009, 16:54 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, 1. check operation.log file and try to find exact name of your phone original firmware version 2. find in support area files with version that is very similar (or the same) as your original version 3. flash phone with firmware only try to power-on phone. If phone can power-on you can try to make "safe" or "complete" format to reset phone to it's default values. |
03-05-2009, 17:03 | #12 (permalink) |
Member: 436045 Status: Offline Sonork: 1581208 Thanks Meter: 31 | Thanks for the reply dear Infinity support.. The matter of fact is i found the same version but still fone's dead after flashing writing eeprom.. It flashes all well but i have errors wen i try to complete format it.. 1st i get this ( Pictures not uploading that's y writing u errors that i m getting) CONFIRM warning: probably flash chip is empty, erased incorrectly flashed or damaged.. What to do: 1) got to software ................... etc 2ndly this error comes Cant detect ffs/eeprom area Do you want to use standar ffs?eeprom address: 00E0000? if sure......................... etc.. help me plz how to fix this problem... very best regards, TOm |
03-05-2009, 18:26 | #13 (permalink) |
Member: 436045 Status: Offline Sonork: 1581208 Thanks Meter: 31 | Wow it worked for me wonderful Infinty support... I tried following files and fone is now ON.. MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_108_0801 23___5310_16m_En_Ru_Fr_Es_Th_Vn_Farsi_Ar.B0M.bin MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_108_0801 23__Nokia-5310_ffs_01.B0E.bin here's the LOG file COM4 [VCP0] selected module v2.77 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:1703:0007 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... error: no any expected answer : wrong answer after chip id request flash: AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.9A4B2838.[MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_116_0803 12.BIN_12B24DB9].rpl identification#1 detection finished device-id: 9A4B2838 identification#1 protocol ver: 04 ver. sw 1: MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_116_0803 12.BIN ver. sw 2: A521_L8EN_116_080312, 46B24DED ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#2... detection phase #1... . detect device identification#2 finished security area (code #1) calculation... done detecting security area (code #2)... security area (code #2) is absent file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_9A4B2838_MTK25_06B_PCB01_GPRS_MT6225_S00 .A521_L8EN_116_080312.BIN_12B24DB9_20090305-215618.B0X.bin Area: Firmware flash: EC257E25082501:18E59F00000000 Write: Firmware Area: Eeprom/ffs flash: EC257E25082501:18E59F00000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . detect device identification#2 finished Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_9A4B2838_MTK25_06B_PCB01_GPRS_MT6225_S00 .A521_L8EN_116_080312.BIN_12B24DB9_20090305-220606.B0X.bin Finished, time used: 616 sec Remove/Install battery now ! So now i have learnt that similar files DO WORK.. Thanks every1... Br, TOm @ Future Fones Uk/Pk |
Cect T689 DEAD REALY DEAD | klub-guy | Chinese Models & Cloned Phones | 5 | 02-05-2009 15:46 |
E1 Totaly Dead.. :( :( Not enter Boot Mode.. | LoveLess | Motorola P2k | 9 | 12-03-2007 14:23 |
E1 Totaly Dead.. :( :( Not enter Boot Mode.. | LoveLess | Motorola Hardware Repair | 1 | 12-01-2007 10:17 |
BE5 (OT701) v124 dead !!! :( | majid | Alcatel & TCL Old Models | 1 | 12-25-2001 11:05 |
C28 dead :( , i ned flash c28 ver6.1 for total flasher | cianyika | x1x to x45/x50 | 0 | 04-06-2001 15:32 |
