Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2006
Member: 281925 Status: Offline Sonork: 100.113915 Thanks: 26
| cect v180 restarting problem but after ffs same problem i have cect v180 restarting problem when put sim card i do ffs complite but phone have same problem phone have two cpu and connact with rx1 tx1 not connact with rx2 tx2 how to do ? |
| | #3 (permalink) | |
| Quote:
i meen does't work with one card and is there any solution to format spread cpu phone bcoz i test in more then 10 sets infinity box not detact phone why ? | |
| | #6 (permalink) |
| now succsesfully repaier cect v180 dual cpu phone after flash now succsesfully repaier cect v180 dual cpu phone after flash here log Code: ==== log opened: [2/3/2008 6:27:52 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.exe Loading data, wait... [Infinity Box] v2.24 S/N: :D:D:D:D:D:D Wait... Device: Autodetect 6205-6227 NOR Done Loading file v.02... CM_Cect-V180-2sim_E553_KT3F8C_E553_GPRS_MT6226_S01.01_1_16m_En_Ru_Fr_Es_De_Th_Vn_Tr_Ar.B0M.bin loaded identification#1 protocol ver: 04 ver. sw1: E553_KT3F8C_E553_GPRS_MT6226_S01.01_1.BIN ver. sw2: E553_KT3F8C.01.1, B384BCA2 You have loaded file with security features enabled. Languages: En Ru Fr Es De Th Vn Tr Ar COM5 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization skip: Language Pack skip: Eeprom/ffs Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:DF00:5A84 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.DFE42F46.[E553_KT1C_E553_GPRS_MT6226_S01.01_1.BIN_D3437A28].rpl identification#1 detection finished device-id: DFE42F46 identification#1 protocol ver: 04 ver. sw1: E553_KT1C_E553_GPRS_MT6226_S01.01_1.BIN ver. sw2: E553_KT1C.01.1, D785BC2C ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF reading [eeprom[E553_KT1C_E553_GPRS_MT6226_S01.01_1.BIN]]... file saved: C:\Documents and Settings\MODIATOR\Desktop\gunjan\backup_eeprom[E553_KT1C_E553_GPRS_MT6226_S01.01_1.BIN]_20080203-183454.B0E.bin flash: EC257E25082501:29EA0000000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished security area#1 calculation... done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log_DFE42F46_E553_KT1C_E553_GPRS_MT6226_S01.01_1.BIN_D3437A28_20080203-183505.B0X.bin Area: Firmware flash: EC257E25082501:29EA0000000000 Write: Firmware Write Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log_DFE42F46_E553_KT1C_E553_GPRS_MT6226_S01.01_1.BIN_D3437A28_20080203-184048.B0X.bin Finished, time used: 635 sec Remove/Install battery now ! Code: CM_Cect-V180-2sim_E553_KT3F8C_E553_GPRS_MT6226_S01.01_1_16m_En_Ru_Fr_Es_De_Th_Vn_Tr_Ar.B0M.bin [new] |
| | #7 (permalink) |
| i done ffs by E$ box [restarting] Spider$$$ box [display not showing any icon meen phone start but whit light ] and also infinity box [still restarting ] then after flash phone work well thx to akhil ray for best support |
| | #9 (permalink) | |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: infinity-box
Member: 130995 Status: Offline Thanks: 9,039
| Quote:
Please, check: http://www./showthread.php?t=513540 | |
| | #10 (permalink) |
| Junior Member Join Date: Nov 2008 Location: Bamberg, Bavaria, GERMANY
Member: 904681 Status: Offline Thanks: 0
| Cect V180 FlashFile? Where 2 get it? Hello everybody... Please, where can I get those file?: CM_Cect-V180-2sim_E553_KT3F8C_E553_GPRS_MT6226_S01.01_1_16m_En_ Ru_Fr_Es_De_Th_Vn_Tr_Ar.B0M.bin If somebody would give me an active link (maybe a newer/better file for this phone) for downloading this file would be pretty fine. ![]() Oh... I'll buy a USB unlocking/flashing cable just 4 that phone. So there is everything I need (Box inbetween the cable). If those file doesn't work with "freeware" (and without any flash-boxes), please let me know a functional file-link... I'll pay a beer (sorry, just virtual) for the uploader ![]() Thanx a lot |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Sigmatel restart with sim after ffs etc. | Riteshgpt60 | Chinese Miracle & PinFinder | 25 | 04-17-2010 11:24 |
| N88 Restarting after Format same problem.. | ASHRIFF | Chinese Miracle & PinFinder | 8 | 04-23-2008 11:32 |
| Cect V180 Format OK But Same Problme !!!! | kalpeshoza | SpiderMan | 5 | 03-19-2008 05:03 |
| CECT V180 restart | manyosa | Chinese Cocktail | 8 | 12-08-2007 10:58 |
| Anycool D66 After Ffs Same Problem | jothi737 | Chinese Miracle & PinFinder | 2 | 11-11-2007 12:11 |
