11-12-2008, 16:27 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: -=HORIZON=-MobiSoft Rahwali GR Age: 38
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | Cect V8 dead I have tried to flash but error. here is the log: COM13 [VCP0] selected module v2.68 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:6F8C:B9E3 high speed disabled boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 2BEA00F018E59F:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 2BEA00F018E59F:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 2BEA00F018E59F:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 2BEA00F018E59F:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: RATECH26_06A_PCB01_GPRS_MT6226_S01.S800FB.26B.TS.B TM_06A_PRD_V030.C14.D_0003.BIN ver. sw 2: PRD_V030.C14.D, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 2BEA00F018E59F:2BEA0000000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[RATECH26_06A_PCB01_GPRS_MT6226_S01.S800FB.26B.TS.B TM_06A_PRD_V030.C14.D_0003.BIN]... file saved: E:\Documents and Settings\HORIZON\Desktop\100MSDCF\eeprom[RATECH26_06A_PCB01_GPRS_MT6226_S01.S800FB.26B.TS.B TM_06A_PRD_V030.C14.D_0003.BIN]_20081112-202701.B0E.bin flash: 2BEA00F018E59F:2BEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting security area (code #2)... security area (code #2) is absent Area: Firmware flash: 2BEA00F018E59F:2BEA0000000000 Write: Firmware error: error# 0000002B error: flash write error: 00000000:00002000 error: error# 0000002B error: flash write error: 00000000:00002000 error: error# 0000002B error: flash write error: 00000000:00002000 error: error# 0000002B error: flash write error: 00000000:00002000 error: error# 0000002B error: flash write error: 00000000:00002000 error: error# 0000002B error: flash write error: 00000000:00002000 error: error# 0000002B error: flash write error: 00000000:00002000 error: error# 0000002B error: flash write error: 00000000:00002000 error: error# 0000002B error: flash write error: 00000000:00002000 error: error# 0000002B error: flash write error: 00000000:00002000 error: error# 0000002B error: flash write error: 00000000:00002000 error: error# 0000002B error: flash write error: 00000000:00002000 error: error# 0000002B error: flash write error: 00000000:00002000 error: error# 0000002B error: flash write error: 00000000:00002000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Write Fail Finished, time used: 476 sec Remove/Install battery now ! Same file not found on the site! RATECH26_06A_PCB01_GPRS_MT6226_S01.S800FB.26B.TS.B TM_06A_PRD_V030.C14.D_0003.BIN]_20081112-200911 above was my file. RATECH26_06A_PCB01_GPRS_MT6226_S01.S800FDB.26B.TS. BTM_06A_MWKS_V003.C15.H_0003_16m_En_Ru_Fr_Es_Th_Vn _Ar this file i used urgent please |
11-13-2008, 07:52 | #3 (permalink) |
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | sir, if flash reading is working fine! even then there is possibility of chip problem???? It is reading fine but error in writing! also wants to know that is there no problem in difference in files?? |
11-13-2008, 09:28 | #4 (permalink) |
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | i have also mentioned that set is not completely dead. it powers on when i use operation format ffs: safe mode. here is log: COM13 [VCP0] selected module v2.68 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:6F8C:B9E3 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 112 sec Remove/Install battery now ! |
cect v8 dead in spiderman | lilan sahoo | SpiderMan | 2 | 11-11-2008 09:48 |
cect v8 pinout here | alavudeen | Infinity-Box | 1 | 11-01-2007 23:03 |
cect v8 pinout | sonetek | Infinity-Box | 1 | 11-01-2007 20:17 |
infinity-box support cect v8? | dimitron | Infinity-Box | 3 | 06-24-2007 14:33 |
