10-04-2009, 11:05 | #1 (permalink) | |
No Life Poster Join Date: Aug 2009 Location: Ph country
Member: 1104730 Status: Offline Thanks Meter: 446 | cherry mobile model: D20= default code; 1122, TestCode : *#433979# M35= default: 0000, Testcode: *#3226# D50= default:1234, Testcode: *#8888#, sw version: *#8818# Quote:
10-04-2009, 11:17 | #2 (permalink) | |
Banned Join Date: Jul 2005 Location: Philippines Age: 53
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | Quote:
BR.... | |
The Following User Says Thank You to FullFLASHgSMPH For This Useful Post: |
10-04-2009, 12:04 | #3 (permalink) |
Member: 1104730 Status: Offline Thanks Meter: 446 | ROCK N ROLL SOLVED AND RESET COM13 [VCP3] selected module v2.91 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "user code" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:AF41:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.5DF72BC1.[HEDY23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.MAUI_08A _W08_28_V001_PL_25_60.BIN_00FDB2F4].rpl ==================== New firmware detected (v.2.91, database date: unknown): HEDY23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.MAUI_08A _W08_28_V001_PL_25_60.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: 5DF72BC1 rom info protocol ver: 04 ver. sw 1: HEDY23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.MAUI_08A _W08_28_V001_PL_25_60.BIN ver. sw 2: MAUI.08A.W08.28.V001.PL.25.60, 0B4D02FF ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 01227E22202200:2BEA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent detecting ffs/eeprom structure pass 1... .......................... detect standard fat location pass #1... detect standard fat offset pass #1... detect standard fat location pass #2... .......... detect standard fat offset pass #2... detect standard fat location pass #3... detect standard fat offset pass #3... detect standard fat location pass #4... detect standard fat offset pass #4... detect standard fat location pass #5... detect standard fat offset pass #5... detect standard fat location pass #6... detect standard fat offset pass #6... detect standard fat location pass #7... ............................................. detect extended fat location pass #7... ............................... detect standard fat offset pass #7... detect standard fat data... fat layout detection complete ffs/eeprom detected ok: element #1 startup code area #1 check... startup code area #1 fixed detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: HEDY23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.MAUI_08A _W08_28_V001_PL_25_60__ffs... file saved: C:\Documents and Settings\GSM Baguio\Desktop\HEDY23C_08A_GEMINI_PCB01_GPRS_MT622 3P_S00.MAUI_08A_W08_28_V001_PL_25_60__ffs_20091004-185101.B0E.bin flash: 01227E22202200:2BEA0000000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done Special operation ... Special operation Done Write ... flash: 01227E22202200:2BEA0000000000 Write: eeprom Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\H EDY23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.MAUI_08A_ W08_28_V001_PL_25_60__system_log_5DF72BC1_00FDB2F4 _20091004-185319.B0X.bin Finished, time used: 450 sec Remove/Install battery now ! |
The Following User Says Thank You to Babyunlocker For This Useful Post: |
10-04-2009, 21:17 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! thank you for your good test report! may i have this flash file for our collection? our email is [email protected] thanks in advance! |
11-03-2010, 11:17 | #7 (permalink) | |
Junior Member Join Date: Feb 2007
Member: 448210 Status: Offline Thanks Meter: 4 | Quote:
Pls Support these Phones - Cherry Mobile | Rabatu | Infinity-Box | 6 | 07-22-2012 03:05 |
cherry mobile 1800 needed help | andy_lecnah | Infinity-Box | 4 | 03-28-2010 04:52 |
Cherry Mobile is it supported? | jr astigin | Infinity-Box | 2 | 02-19-2010 12:23 |
How to use infinity in servicing cherry mobile | baywalker | Infinity-Box | 2 | 02-07-2010 11:14 |
