03-02-2011, 09:14 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: EARTH
Member: 259397 Status: Offline Thanks Meter: 76 | China a200 restart when making call when make a call restart .... i also flash ... newfirmwares from supprt aria... also .. format ffs complete . but ... when making call phone restart ..in incoming call. phone cannot restart .. working .. well.... plz experts.. how to solve it .... here is flashing log . COM15 [VCP0] selected module v3.27 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_F_ABROAD_5CDG B_S5LCD_V1_9_8__NKTEL-A200_w_eeprom.B0E.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:7703:000E status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: c:\InfinityBox\ChineseMiracle\backup_security\id.6 802CD0B.[N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_F_ABROAD_5CDG B_S5LCD_V1_9_8.BIN_E24DA3CF].rpl rom info detection finished device-id: 6802CD0B rom info ver: 04 sw version: N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_F_ABROAD_5CDG B_S5LCD_V1_9_8.BIN project-id: N66_F_ABROAD_5CDGB_S5LCD_V1.9.8, CFA34DE2 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Code CRC check error fix... firmware do not have "Code CRC check error" area No licensed to produce fix... warning: firmware do not have this kind of fault Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent file saved: c:\InfinityBox\ChineseMiracle\backup_security\N66_ ABROAD_PCB01_GPRS_MT6225_S00.N66_F_ABROAD_5CDGB_S5 LCD_V1_9_8__system_log_6802CD0B_E24DA3CF_20110302-131022.B0X.bin Area: Firmware flash: 98000300000001:18E59F00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: c:\InfinityBox\ChineseMiracle\backup_security\N66_ ABROAD_PCB01_GPRS_MT6225_S00.N66_F_ABROAD_5CDGB_S5 LCD_V1_9_8__system_log_6802CD0B_E24DA3CF_20110302-131128.B0X.bin Finished, time used: 1 min 44 sec Remove/Install battery now ! |
The Following User Says Thank You to Tanveer_city01 For This Useful Post: |
Nokia 6110 without net. couldn´t call 911 either! | DennisT | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 05-09-2000 11:37 |
I need info doc to make scripts for send.exe ThanksĦĦ | Bolo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 04-09-2000 11:49 |
Need help to make a site for free software | hicom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 10-14-1999 22:57 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
