02-11-2011, 09:27 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Afrique du sud Age: 42
Member: 430612 Status: Offline Thanks Meter: 301 | china e71 dead after fomat module v3.26 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:7503:0007 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files (x86)\InfinityBox\ChineseMiracle\backup_security\i d.99122F4A.[PUYANG25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_F2.BIN_457F7661].rpl ==================== New firmware found (v.3.26, database date: 13.01.2011): PUYANG25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_F2.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: 99122F4A rom info ver: 04 sw version: PUYANG25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_F2.BIN project-id: MAUI.GEMINI.W08.12.F2, 61767F45 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: PUYANG25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_F2__ffs... file saved: C:\Program Files (x86)\InfinityBox\ChineseMiracle\PUYANG25_GEMINI_P CB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12_F2__ffs_20 110211-102116.B0E.bin flash: EC257E25082501:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:18E59F00000000 Finalization Done file saved: C:\Program Files (x86)\InfinityBox\ChineseMiracle\backup_security\P UYANG25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W 08_12_F2__system_log_99122F4A_457F7661_20110211-102140.B0X.bin Finished, time used: 5 min 8 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! phone was restarting before fomat and now phone is dead |
02-13-2011, 19:53 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please do following: load this file as EEPROM: C:\Program Files (x86)\InfinityBox\ChineseMiracle\PUYANG25_GEMINI_P CB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12_F2__ffs_20 110211-102116.B0E.bin write back to phone. this will bring it to Restart condition again. after that try Format FFS, but "SAFE" mode |
02-14-2011, 03:53 | #5 (permalink) |
Insane Poster Join Date: Dec 2009
Member: 1178397 Status: Offline Sonork: [email protected] Thanks Meter: 6 | e-71 on/off e-71 on/off it is hardware prob 1-back site of pcb clean up dry it 2-revole cpu |
5110 v 6.0 after unlocking problem with net | cole | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-10-2001 16:11 |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
"Menu 11"? after Net monitor | Pyron | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-09-1999 10:07 |
