Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > Chinese Miracle & PinFinder
Old 11-08-2009, 10:03   #1 (permalink)
Member: 447849
Sonork: 100.1604076
China (E71i) with sim not working w/o sim working fine
Here is the formatting log
i have done many times but not success yet ....
infinity team what is this problem ??
COM11 [VCP0] selected
module  v2.96
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:0003:000F
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
921600
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
New firmware detected (v.2.96, database date: 27.10.2009):
GOLDDRAGON25_GEMINI_PCB03_GPRS_MT6225_S00.GDL138_HONGBT_DSIM_ST_V09.BIN
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send flash backup files to support: mt62xx@gmail.com or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info protocol ver: 04
ver. sw 1: GOLDDRAGON25_GEMINI_PCB03_GPRS_MT6225_S00.GDL138_HONGBT_DSIM_ST_V09.BIN
ver. sw 2: GDL138_HONGBT_DSIM_ST_V09, 00000000
address offset: 00000000
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: GOLDDRAGON25_GEMINI_PCB03_GPRS_MT6225_S00.GDL138_HONGBT_DSIM_ST_V09__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\GOLDDRAGON25_GEMINI_PCB03_GPRS_MT6225_S00.GDL138_HONGBT_DSIM_ST_V09__ffs_20091107-145503.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 150 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
B.R.,
Sonu
Old 11-08-2009, 10:50   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
module  v2.96
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
921600
Set baud Done
TCL-ID is absent
ffs/eeprom chip: 00
Write ...
Write Done
Finalization ...
ffs formatting...
Finalization Done
B.R.,
Sonu
Hello,
Here is an information:
http://www.infinity-box.com/wiki/ind...ot_make_a_call
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 11-08-2009, 11:03   #3 (permalink)
Member: 447849
Sonork: 100.1604076
Without sim fone working ok
but during make emergency call also fone goea off
its mean....HW fault
B.R.,
Sonu
Originally Posted by InfinitySupport View Post
Old 11-08-2009, 20:30   #4 (permalink)
Member: 148515
hello!
yes, in most cases this is power amplifier fault
Old 12-10-2009, 09:26   #5 (permalink)
Member: 425881
Wink
full flash with infinity you set will be 100% OK.
Old 12-10-2009, 14:52   #6 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
hello i was also have this problem with my NKTEL 2008 & i do full flash many more files but that still on restart problem i think its hardware foult......
Old 12-10-2009, 18:51   #7 (permalink)
Member: 148515
Samsung phone doesnt work on Globe but works fine with SMArt 25531 Samsung Flashers, Software, Firmware. 0 08-12-2009 09:40
6280 restart when camera on with memory card,without memory card camera works fine shivam4you Nokia Hardware & Hardware-Repair Area 1 01-19-2009 10:54
Tornado SIM not Work with Movistar Sim Mexico gniusmx TORNADO - SIM 0 07-20-2008 21:08
Page generated in 0.93340 seconds with 11 queries
