11-13-2008, 07:01 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: I.N.D.I.A
Member: 385162 Status: Offline Thanks Meter: 598 | China flash file need COM8 [VCP2] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6219:8B02:8B01]... CPU: MT6219 high speed boot enabled CPU: MT6226MA detected chip: 0031:B341:415C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E223C2200:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E223C2200:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin number of flash chip/regions detected: 01/01 total flash region size: 02000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 01000000 flash: 01227E223C2200:FFFFFF00000000 checking area[00000000]: 00000000-01FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 01000000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 01000000 ffs chip: 00 eeprom/ffs area: 00000000:01000000-01FFFFFF detecting ffs structure pass 1... ..................... detect standard fat location pass #1... .................................................. .............. detect extended fat location pass #1... .................................................. .............. fat location can't be detected ffs element #1 detection failed detecting ffs structure pass 2... ..................... detect standard fat location pass #1... .................................................. .............. detect extended fat location pass #1... .................................................. .............. fat location can't be detected ffs element #2 detection failed Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Finished, time used: 92 sec Remove/Install battery now ! PLEASE GIVE ME RIGHT FILE |
The Following 3 Users Say Thank You to dharmeshslnk For This Useful Post: |
11-13-2008, 07:11 | #2 (permalink) |
Freak Poster Join Date: Dec 2007 Location: india
Member: 647592 Status: Offline Thanks Meter: 191 | sir after whole chip ereas it is very difficult to fine right file for phone open set and try to find firmware on it and if u find any firmware their plz post here i will try for help |
5310 china flash file.needed see attach image | dawgweed | Infinity-Box | 4 | 12-15-2013 07:15 |
5310 china flash file needed | 8sme | Nokia Hardware & Hardware Repair | 0 | 02-11-2009 18:52 |
6300 rm217 china flash file needed | beachies16 | Chinese Models & Cloned Phones | 2 | 09-09-2008 03:02 |
N95 Dual Sim China Flash File Needed | waelkawasaki | SpiderMan | 5 | 08-28-2008 23:20 |
N95 Dual Sim China Flash File Needed....!!! | Viga_10 | SpiderMan | 2 | 03-27-2008 21:10 |
