China Mobiles Keypad Solution Many times i have got China mobiles with keypad problems, Actualy i want to know that what is the problem, is it software problem or hardware, how can i guess. Please explain me all. |
Keypad Problem Quote:
hello! we have met very few models which after complete format displayed pushed buttons uncorrectly. for example you press "5" it shows "2" all other problems are hardware faults |
i have problem when you click "1" phone show 6 , "2" is 4, "3" is 5, "4" is 9 i think that is software problem , how i can solve this |
Hello, I suggest you to check hardware first. If you are sure that it's software problem you can try to flash phone with different flash files from Infinity-Box support area |
problem is software, but i flash whit many flashes and only one can power phone and then is keypad wrong, can you edit in flash Keypad map? or any soft can edit flash whit this function |
if you think that it's software problem you have only one method: you must find exactly the same phone and use backup from that phone to repair damaged phone |
software is 100% because phone was restarting and somebody is flash this phone on Spiderman with wrong flash and kill phone |
i hAVE A CHINA MTK CPU SCREEN TOUCH IS WORKING FINE & ALL KEY IS NOT WOKRKING ANY SLOUTION PLESE HELP ME !!! |
maximum keypad problem can be solved by replacing touch screen , ihave tested in many sets |
I also have a set with same problem. touch screen is working fine,while during using its keypad it doesnt working properly. press 1 show 3. press 2 show 7. press menu show something else. all keys r working but with wrong order |
hello mr. astana2007! Did you get this phone in such condition ? or this is a result of some software operation? |
mychina a5 55555555555keylong working only heip me |
Open phone and clean water. Also check phone keyboard, it looks like it's damaged. |
China nckia n79 keypad not working after power phone please any solution |
