Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Junior Member ![]() Join Date: Jun 2008
Member: 791712 Status: Offline Thanks: 2
| China N73 not found pinfinder Hallo! I have just bought infinity & pinfinder I have updated both of them but I can't connect China N73-1 RM-133 (with cable L14F). Here is log: software version: 1.06 cable type: 1x14 DKU-2 (L14F) platform: MT6205, MT6217-MT6228 searching adapter at COM11... adapter found, version: 2000 pins: 14, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 19200 failed to detect pins time required: 82 sec Power Off ! ================ Please help me. |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks: 510
| 1st:-CAN YOU PRESS POWER BOTTOM? 2nd:-WHAT IS YOUR CPU NAME, IF IT IS MT62XX BASE, YOUR FAULT IS CPU, REHIT CPU AND THEN TRY IT. AFTERALL MY FIRST ANS IS:- PRESS POWER BOTTOM STILL DETECTED PINOUT. |
| | #3 (permalink) |
| Phone is switching on but restats with sim. When I power on phone switchs on. I have disasabled phone and make Rx and Tx on board near sim reader and swiched on infinity box without pinfinder. but not connecting. |
| | #4 (permalink) |
| Read Carefully My Post, I Say When You Connect Phone In Pinfinder , Can You Press Your Phone Power Bottom Still Detectedtion Complite? If No First Work It. FORMAT YOUR PHONE 100% SOLUTION. |
| | #5 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005 Location: egypt
Member: 194207 Status: Offline Thanks: 118
| whats the cpu in phone ? can u tell us please cause i have N95 8g also pinfinder cant find rx & tx my cpu is mt6226ma ? so share ur cpu if the same so must answer us one of the infinity team mony_valley |
| | #6 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2004 Age: 38
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks: 238
| pinfinder have fast detection for n73 china (no detection problem.). select cable .... select cpu ... find .... hold power button... ::::very easy:::: i done many n73 with my pinfinder |
| | #7 (permalink) | |
| Quote:
cause i try with mt6226ma many times & not detected by pin finder mony_valley | |
| | #8 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2007 Location: www.espace-gsm.com
Member: 476420 Status: Offline Sonork: 100.1605239 Thanks: 79
| Quote:
| | #10 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: May 2005 Age: 36
Member: 148515 Status: Offline Thanks: 2,319
| hello guys! if pinfinder can not find pins, but you sure that you doing all correctly, because you succesfully found pinout on other phones- only possible reason that this model do not hold tx/rx pins in system connector. you must use test points on PCB instead |
| | #11 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2008 Location: Karachi Age: 23
Member: 788720 Status: Offline Sonork: 100.1617957 Thanks: 102
| hi bro i faced the same problem.n73 cant connect in my pinfinder so i made three pins cable directlyl connected to infinity box not through pinfinder and it boot ok.so try to made a three pin cable.in n73 the starting 3pins are rx tx and ground. |
| | #13 (permalink) |
| hello mr. ayazbazme! please post connector type and what pins is what? @namchito: check with multimeter where is GND pins in your phone, so we could compare with information given by mr. ayazbazme |
| | #14 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2006
Member: 383929 Status: Offline Thanks: 11
| 100% working pinouts me too had the same problem i tried everything but it seems that pinfider cant detect even if you manually set pins in pinfinder put your tongue on the pins of the dku 2 cable i wont have any current so then it construct a rj45 cable with the following pinouts hope it works for you too. |
| | #15 (permalink) |
| now i have n73 the same connector & i try with pin finder to find the rx & tx & fail to detect it so i will try now that pins & post result mony_valley |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Alcatel S120 Flash File not found in support [SOLVED] | surin | PolarBox 2 | 16 | 03-30-2010 10:57 |
| pinfinder adaptor not found in the dongle manager???? | peter002 | Chinese Miracle & PinFinder | 13 | 11-18-2009 05:05 |
| pinfinder not found | lucky_gsm | Infinity-Box | 6 | 01-10-2009 17:09 |
| Dongle not found after upgrading with pinfinder | tavoonly | Infinity-Box | 20 | 10-12-2008 01:38 |
| why did not found have china reseller for samrt clip on samrt clip website? | EOEM | Smart-Clip | 1 | 02-20-2005 20:16 |
