05-28-2009, 15:36 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Pakistan Age: 41
Member: 616556 Status: Offline Thanks Meter: 112 | China Phone Lock Code Problem try all operations,user unlock,sp unlock.all methods but no success safe formate ffs comlete formate Rebuild IMEI repair securty area But same dispaly on screen ((((Phone Lock Code)))) Model Name A8 Double sim cable type: 1x10 (L10A) CPU: MT6226 result: Rx:5 Tx:6 Flash Backup http://rapidshare.com/files/23818196...4.B0M.zip.html Here is opation log COM10 [VCP0] selected module v2.82 Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:53AC:6C0F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: M858BRSDL_V2_6226b_11H Version: M858_01 detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #1... 0 3 4 5 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31error: detection failed (29 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 128 sec Remove/Install battery now ! ===================== COM10 [VCP0] selected module v2.82 Action: unlock unlock method: smart fast Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:53AC:6C0F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: M858BRSDL_V2_6226b_11H Version: M858_01 detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #1... 0 3 4 5 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31error: detection failed (29 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 117 sec Remove/Install battery now ! ======================== COM10 [VCP0] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:53AC:6C0F status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.BA28E53E.[M858BRSDL_V2_PCB01_GPRS_MT6226_S01.M858BRSDL_V2_62 26B_11H.BIN_7DADF72A].rpl ==================== New firmware detected (v.2.82, database date: unknown): M858BRSDL_V2_PCB01_GPRS_MT6226_S01.M858BRSDL_V2_62 26B_11H.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: BA28E53E identification#1 protocol ver: 04 ver. sw 1: M858BRSDL_V2_PCB01_GPRS_MT6226_S01.M858BRSDL_V2_62 26B_11H.BIN ver. sw 2: M858BRSDL_V2_6226b_11H, D5085282 ffs offset/size: 00E00000/00200000 detecting security area (code #2)... .................................................. .................................................. .................................................. .................................................. .................................................. ...... security area (code #2) is absent detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98004900000002:2AEA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting ffs/eeprom structure pass 1... .................... detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. .... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs/eeprom detected ok: element #1 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: M858BRSDL_V2_PCB01_GPRS_MT6226_S01.M858BRSDL_V2_62 26B_11H__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\M858BRSDL_V2_PCB0 1_GPRS_MT6226_S01.M858BRSDL_V2_6226B_11H__ffs_2009 0528-165242.B0E.bin flash: 98004900000002:2AEA0000000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done Special operation ... Special operation Done Write ... flash: 98004900000002:2AEA0000000000 Write: eeprom Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\M 858BRSDL_V2_PCB01_GPRS_MT6226_S01.M858BRSDL_V2_622 6B_11H__system_log_BA28E53E_7DADF72A_20090528-165312.B0X.bin Finished, time used: 449 sec Remove/Install battery now ! ================= COM10 [VCP0] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:53AC:6C0F status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.BA28E53E.[M858BRSDL_V2_PCB01_GPRS_MT6226_S01.M858BRSDL_V2_62 26B_11H.BIN_7DADF72A].rpl ==================== New firmware detected (v.2.82, database date: unknown): M858BRSDL_V2_PCB01_GPRS_MT6226_S01.M858BRSDL_V2_62 26B_11H.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: BA28E53E identification#1 protocol ver: 04 ver. sw 1: M858BRSDL_V2_PCB01_GPRS_MT6226_S01.M858BRSDL_V2_62 26B_11H.BIN ver. sw 2: M858BRSDL_V2_6226b_11H, D5085282 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98004900000002:2AEA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98004900000002:2AEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98004900000002:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\M 858BRSDL_V2_PCB01_GPRS_MT6226_S01.M858BRSDL_V2_622 6B_11H__system_log_BA28E53E_7DADF72A_20090528-164102.B0X.bin Finished, time used: 145 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
05-31-2009, 22:42 | #7 (permalink) |
No Life Poster Join Date: Apr 2008 Location: karachi .. Age: 38
Member: 749969 Status: Offline Sonork: 100.1581886 Thanks Meter: 771 | i also tried on many chinese mobiles but some times no success.. i try all operations like user reset format ffs .. but no success whats the problem is this ? please clear that is this problem only with me or other users also face this problem and .. and also please fix this problem.. thanks to infinity team for very quick reply always.. |
enter phone lock code problem | zeeshan tayyab | Chinese Models & Cloned Phones | 0 | 10-20-2009 09:49 |
K330 Phone Lock code problem- | PASSIONATE_BOYS | Infinity-Box | 5 | 05-26-2009 16:02 |
MyPhone T22 phone lock code problem | lezwire | Chinese Cocktail | 1 | 01-03-2008 07:12 |
w810i phone lock code problem | gaspardiana | Sony Ericsson | 7 | 12-19-2007 18:01 |
T68i PHONE LOCK CODE PROBLEM PLEASE HELP | axilleask | Sony Ericsson | 0 | 12-21-2004 16:51 |
