06-03-2009, 08:44 | #1 (permalink) |
Registered User Join Date: Feb 2008 Location: andhra pradesh
Member: 702331 Status: Offline Thanks Meter: 61 | china set dead by format with infinity arfter format complete mode phone is dead what can i do please help me -infinity team |
06-03-2009, 09:15 | #2 (permalink) |
No Life Poster Join Date: Oct 2005 Location: P A K I S T A N Age: 16
Member: 190344 Status: Offline Thanks Meter: 280 | things to do; 1: if u have back up restore it.set will turn on with the same problem as it had before. 2: if no back up try to search the required file in support area. and flash the phone with the same or closely realted file and post the results br hamid |
06-03-2009, 09:22 | #3 (permalink) |
Member: 702331 Status: Offline Thanks Meter: 61 | there is no flash file in support area any one have please upload ztc zt6618 is phone model flash file name is M370_QVGA_PCB01_GPRS_MT6225_S00.M370_QVGA_INTEL_L_ V2_5_0.BIN |
06-03-2009, 09:37 | #4 (permalink) |
Member: 702331 Status: Offline Thanks Meter: 61 | ==== log: [6/3/2009 12:04:38 PM] ==== COM3 [VCP1] selected module v2.75 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! error: boot initialization step #2 failed: 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001D03:0005 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb it's time to stop: 18F09FE518F003C018F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.75, database date: 21.12.2009): M370_QVGA_PCB01_GPRS_MT6225_S00.M370_QVGA_INTEL_L_ V2_5_0.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: M370_QVGA_PCB01_GPRS_MT6225_S00.M370_QVGA_INTEL_L_ V2_5_0.BIN ver. sw 2: M370_QVGA_INTEL_L_V2.5.0, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 89880F00010001:89880F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E20000 Detected ffs/eeprom address is non-standard: 00E20000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make full flash backup for emergency case 3. repeat required operation terminated by user error: critical error#1 during ffs/eeprom size detection error: can't detect ffs/eeprom address/size Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 89880F00010001:89880F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 89880F00010001:89880F00000000 Finalization Done Finished, time used: 56 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! phone is dead after format |
06-03-2009, 09:42 | #5 (permalink) |
Member: 702331 Status: Offline Thanks Meter: 61 | COM3 [VCP0] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001D03:0005 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb Warning: probably flash chip is empty, erased, incorrectly flashed or damaged ! What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. E:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. E:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 89880F00010001:89880F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E20000 Detected ffs/eeprom address is non-standard: 00E20000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00E20000 detecting ffs/eeprom size... ffs/eeprom size: 001E0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E20000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 89880F00010001:89880F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 89880F00010001:89880F00000000 Finalization Done Finished, time used: 127 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On |
06-03-2009, 13:53 | #6 (permalink) |
Crazy Poster Join Date: Mar 2009
Member: 984054 Status: Offline Sonork: 12345 Thanks Meter: 9 | you should not give yes when it shows "Detected ffs/eeprom address is non-standard: 00E20000" now only option is full flash with the og file i'll try to post if file is available jai sri ganesh |
06-03-2009, 23:01 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! have you made backup as program asked you? if not- you must find flash file somewhere else, because we dont have it in our support area collection |
Help infinity team china set dead after full format? | malikawan | Infinity-Box | 3 | 10-02-2009 10:38 |
china cect t818 sucsecssfully format in infinity with auto pinout finder adpter | .::AZEEM::. | Infinity-Box | 2 | 07-02-2009 00:35 |
china mobile dead by format with infinity | DIN231080 | Chinese Models & Cloned Phones | 3 | 04-25-2009 03:06 |
china mobile dead by format with infinity | DIN231080 | SpiderMan | 4 | 04-15-2009 12:34 |
china n92 dualsim phone dead after format with infinity | /ARIF/ | Chinese Models & Cloned Phones | 1 | 03-22-2008 01:24 |
