09-20-2010, 14:51 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: in heart of innocent peoples Age: 34
Member: 407782 Status: Offline Sonork: 100.1586820 Thanks Meter: 1,052 | chine nktel 2008 do repair block both imei, writ imei both still no success. whats the problem? here is logs ==== C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e [9/20/2010 6:34:32 PM] ==== Loading data, wait... [Infinity Box] Chinese Miracle v3.09 smart-card: connected S/N: 4B94:0116 Wait... Device: Autodetect 6205-6227 NOR Done WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [9/20/2010 6:36:02 PM] ==== COM5 [VCP0] selected module v3.09 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:E503:0008 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.5439B5DD.[5800_ABROAD_PCB01_GPRS_MT6225_S00.N96_P14_GC0309_S 5T2220_V1_3_0.BIN_7297A3CE].rpl rom info detection finished ==================== New firmware detected (v.3.09, database date: unknown): 5800_ABROAD_PCB01_GPRS_MT6225_S00.N96_P14_GC0309_S 5T2220_V1_3_0.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: 5439B5DD rom info ver: 04 sw version: 5800_ABROAD_PCB01_GPRS_MT6225_S00.N96_P14_GC0309_S 5T2220_V1_3_0.BIN project-id: N96_P14_GC0309_S5T2220_V1.3.0, CEA39772 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: 5800_ABROAD_PCB01_GPRS_MT6225_S00.N96_P14_GC0309_S 5T2220_V1_3_0__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\5800_ABROAD_PCB01 _GPRS_MT6225_S00.N96_P14_GC0309_S5T2220_V1_3_0__ff s_20100920-184120.B0E.bin flash: 98000300000001:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\5 800_ABROAD_PCB01_GPRS_MT6225_S00.N96_P14_GC0309_S5 T2220_V1_3_0__system_log_5439B5DD_7297A3CE_2010092 0-184149.B0X.bin Finished, time used: 5 min 24 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Action: "repair imei" Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 135790246811220 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 358280015677574 verification Ok Finished, time used: 12 sec Remove/Install battery now ! Action: "repair imei" Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-2: 135790246811220 imei write method: mode-1 imei write channel: imei #2 for dual sim/mono CPU new imei-2: 350724305362320 verification Ok Finished, time used: 7 sec Remove/Install battery now ! still restarting in call. |
how to unlock phone code C25 v05, chines 2588? | Siemens man | x1x to x45/x50 | 13 | 12-07-2002 05:54 |
chines A1118 phone code how unlock? | Siemens man | x1x to x45/x50 | 4 | 08-29-2002 08:26 |
russan and chines and arabian lang for alcatel BF | fox | Main Sales Section | 1 | 04-09-2002 21:54 |
Siemens S35Flash 2004 needed, who needs 2008? | Erik | x1x to x45/x50 | 0 | 07-11-2001 13:17 |
need flash 2004_S35 got 2008 if needed | Erik | x1x to x45/x50 | 0 | 07-04-2001 14:36 |
