Chines iphone Q380 No power on cect Q380-A Am full flashed Full Formated Still no power on Plz help me infinity team Thanx&Regards KOTESHWAR |
yes please give me the deatails:eek: Quote:
COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:AA03:0001 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: R:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.E644D0A6.[TOPWISE25_07A_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_3 2_MP_V7_M521.BIN_B5F5B34B].rpl identification#1 detection finished device-id: E644D0A6 identification#1 protocol ver: 04 ver. sw1: TOPWISE25_07A_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_3 2_MP_V7_M521.BIN ver. sw2: MAUI.07A.W07.32.MP.V7_M521, B44C0A4A ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:18E59F00000000 Finalization Done file saved: R:\Program Files\InfinityBox\ChineseMiracle\system_log_E644D0 A6_TOPWISE25_07A_PCB01_GPRS_MT6225_S00.MAUI_07A_W0 7_32_MP_V7_M521.BIN_B5F5B34B_20080823-161550.B0X.bin Finished, time used: 61 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! but not Powered-On |
pls give me the iphone pinout thnx |
hello celltronix_cbe! flash your phone, if it doesnt power On |
i have same prob help please |
hello mr. piratekhan2! if flashing with correct flash file do not help- try to make format FFS complete. if still not luck- check hardware |
