Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > Chinese Miracle & PinFinder
Old 11-23-2008, 11:58   #1 (permalink)
CONCORDIA GSM's Avatar
Member: 209722
Chinese 6070-RH37 Successfully Alive ***
Hello
Today i gott a dead chinese copy nokia 6070.
I use just format and unit successfully alive with infinity.
THANKS TO INFINITY TEAM.
Look log below.
COM65 [Serial2] selected
module v2.69
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A04]...
CPU: MT6223
high speed boot enabled
chip: 0011:56DB:000C
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 01227E22102201:2AEA0000000000
flash: Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
230400
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00800000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw 1: HEXING23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36 _27.BIN
ver. sw 2: MAUI.07A.W07.36.27, 00000000
ffs offset/size: 00700000/00100000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00700000
checking area [00000000]: 00000000-007FFFFF...
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00700000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs address selected by user
detecting eeprom/ffs size...
eeprom/ffs size: 00100000
ffs chip: 00
eeprom/ffs area: 00000000:00700000-007FFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: eeprom[HEXING23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36 _27.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[HEXING23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36 _27.BIN]_20081123-165118.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 78 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following User Says Thank You to CONCORDIA GSM For This Useful Post:
Old 11-23-2008, 12:25   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
Old 02-03-2009, 18:52   #3 (permalink)
Member: 443226
Originally Posted by ~ Nawab Traders ~ View Post
Hello
Look log below.
module v2.69
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
Boot Done
Initialize ...
Initialize Done
Set baud ...
230400
Set baud Done
ffs chip: 00
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
What module did you use? I have tried chinese miracle module it can't fomat.
Old 02-03-2009, 19:35   #4 (permalink)
Member: 148515
hello!
what error do you get? maybe you using wrong pinout or cable is assembled wrong?
Old 02-04-2009, 19:56   #5 (permalink)
Member: 443226
hello!
It couldin't just connect. I used the right rx and tx on the pcb with rj45 2 and 3 respectively.Anyway my client has picked the phone, i will try again when i get another set.
5230 boot display SIM card invalid ATF success with good repair! 20442044 Advance-Box 1 03-30-2010 03:08
chinese miracle t108 successful repaired delchoni Chinese Miracle & PinFinder 7 02-05-2009 15:45
6300 rh37 chinese pinout help me SAKİR İSLEK Chinese Miracle & PinFinder 10 06-29-2008 11:57
N73 Chinese Miracle Phone -successfully Repair clearcom Chinese Miracle & PinFinder 4 10-13-2007 06:33
Page generated in 3.41305 seconds with 11 queries
