08-12-2011, 19:09 | #1 (permalink) |
Freak Poster Join Date: May 2007 Location: Nic@r@gu@ Age: 41
Member: 516363 Status: Offline Sonork: 100.1601307 Thanks Meter: 35 | chinese models not supported need... platform: MT: MT62xx (autodetect) cable type: 1x5 (L5B) mode: Slow searching adapter at COM3 (115200)... adapter found, version: 2000 Loading platforms configuration... Initializing platforms... Press and HOLD phone Power button now ! pins: 5, plain power/activation cycles: 1/7 power-off delay: 20 start Rx/Tx: 1/1 detecting pins... 19200 fixed CPU: MT6235 result: Rx:3 Tx:2 time required: 6 sec Trying to Power-On... Power is On COM3 [VCP0] selected module v3.31 Device: Autodetect 6228-6268 NAND Checking data, wait... Action: read/check information interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 0.0/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D chip size: 0Mb otp status/size: S_DONE/00000000 NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C chip size: 0Mb page/spare size: 0000/0000 pages per block: 0000 bits i/o: 00 address cycles: 00 internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 error: can not boot device: 07D4:S_BROM_DOWNLOAD_DA_FAIL error: last error: 07D4:S_BROM_DOWNLOAD_DA_FAIL Disconnect... done Finished, time used: 9 sec Remove/Install battery now ! |
08-12-2011, 19:31 | #2 (permalink) |
Member: 516363 Status: Offline Sonork: 100.1601307 Thanks Meter: 35 | COM3 [VCP0] selected module v3.31 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8403:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent ==================== New firmware found (v.3.31, database date: 12.02.2011): R370M00_PCB01_GPRS_MT6225_S00.N_V591_Y30M10_0705_0 8A0812M_1_4D090812C01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 04 sw version: R370M00_PCB01_GPRS_MT6225_S00.N_V591_Y30M10_0705_0 8A0812M_1_4D090812C01.BIN project-id: N.V591.Y30M10.0705.08A0812M.1.4D090812C01, 00000000 code offset: 00000000 ffs offset/size [01]: 00F00000/00100000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00F00000 standard ffs/eeprom offset confirmed: 00F00000 detecting ffs/eeprom size... ffs/eeprom size: 00100000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00F00000-00FFFFFF firmware area: 00000000-00EFFFFF detecting ffs/eeprom structure pass 1... ........................ ffs/eeprom: detect std location pass #1... .................................................. ..... ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: R370M00_PCB01_GPRS_MT6225_S00.N_V591_Y30M10_0705_0 8A0812M_1_4D0908 detecting firmware build... .................................................. ..... firmware date/time: 2009-08-12 22-01 hw1: REBOUND25_GEMINI_HW hw2: Memory-ST_T3W_15+1_128+32 done detecting product-id... .................................................. .............. done detecting languages... ................................................ language parameters detected detected languages: En Fr Es It Tr Farsi Pt Ar Finished, time used: 1 min 48 sec Remove/Install battery now ! |
08-12-2011, 19:52 | #3 (permalink) |
Member: 516363 Status: Offline Sonork: 100.1601307 Thanks Meter: 35 | im trying to remove user code from this 3 handsets software version: 1.26 platform: MT: MT62xx (autodetect) cable type: 2x5 (L10C) mode: Slow searching adapter at COM3 (115200)... too many retries adapter found, version: 2000 Loading platforms configuration... Initializing platforms... Press and HOLD phone Power button now ! pins: 10, plain power/activation cycles: 1/7 power-off delay: 20 start Rx/Tx: 1/1 detecting pins... 19200 fixed CPU: MT6235 result: Rx:2 Tx:1 time required: 6 sec Trying to Power-On... Power is On COM3 [VCP0] selected module v3.31 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 21 sec Remove/Install battery now ! |
08-13-2011, 10:39 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @fernando reyes you have selected very bad way to ask for help. What was the reason to make so stupid thread name ? please, explain. Thank you in advance for your nice explanation. |
08-13-2011, 16:47 | #6 (permalink) | |
No Life Poster Join Date: Jul 2008 Location: pakistan hafizabad
Member: 811013 Status: Offline Sonork: 03468717163 Thanks Meter: 744 | Quote:
select cpu tyep Autodetect MT6228-6268 NAND 100 okkkkkkkkkkkkkkkkk | |
08-13-2011, 16:50 | #7 (permalink) | |
08-14-2011, 17:46 | #8 (permalink) | |
Member: 516363 Status: Offline Sonork: 100.1601307 Thanks Meter: 35 | Quote:
Im gonna be more carefull next time and im gonna try to explain it more clear. thank you for your understanding im sorry | |
08-14-2011, 18:39 | #9 (permalink) | |
module v3.31 Action: read unlock codes unlock method: read codes Model: Autodetect 6228-6268 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... warning: wrong packet cs error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 1 min 32 sec Remove/Install battery now ! | |
08-14-2011, 18:54 | #10 (permalink) |
Member: 516363 Status: Offline Sonork: 100.1601307 Thanks Meter: 35 | COM3 [VCP0] selected module v3.31 Action: read unlock codes unlock method: read codes Model: Autodetect 6228-6268 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8403:000A status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 1 min 17 sec Remove/Install battery now ! |
08-15-2011, 07:17 | #12 (permalink) | |
Insane Poster Join Date: Jun 2011
Member: 1600899 Status: Offline Thanks Meter: 7 | Quote:
08-16-2011, 22:56 | #15 (permalink) | |
module v3.31 Action: read unlock codes unlock method: read codes Model: Autodetect 6228-6268 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8403:000A status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41error: detection failed (42 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 8 min 8 sec Remove/Install battery now ! | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
