10-13-2010, 14:05 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: -=HORIZON=-MobiSoft Rahwali GR Age: 38
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | Chinese MT6226 problem. WBR |
10-13-2010, 14:15 | #2 (permalink) |
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | after restoring eepro set is on but same problem with sim restart. now how to solve?? WBR COM53 [VCP0] selected module v3.24 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs E553_K4SMCHARAB_E553_GPRS_MT6226_S01.01_1__ffs_201 01013-174759.B0E.bin ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:9734:660C status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.9EA6ACA2.[E553_K4SMCHARAB_E553_GPRS_MT6226_S01.01_1.BIN_68D7 0254].rpl rom info detection finished device-id: 9EA6ACA2 rom info ver: 04 sw version: E553_K4SMCHARAB_E553_GPRS_MT6226_S01.01_1.BIN project-id: E553_K4SMCHARAB.01.1, 5402D768 code offset: 00000000 ffs offset/size [01]: 00800000/001FF000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\E 553_K4SMCHARAB_E553_GPRS_MT6226_S01.01_1__system_l og_9EA6ACA2_68D70254_20101013-175745.B0X.bin Area: Eeprom/ffs flash: EC257E25082501:29EA0000000000 Write: Eeprom/ffs sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\E 553_K4SMCHARAB_E553_GPRS_MT6226_S01.01_1__system_l og_9EA6ACA2_68D70254_20101013-181136.B0X.bin Finished, time used: 14 min 47 sec Remove/Install battery now ! |
10-13-2010, 14:25 | #3 (permalink) |
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | after formating safe mode problem solved. Thanks Infinity WBR |
The Following User Says Thank You to msashami For This Useful Post: |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
