09-02-2010, 20:51 | #1 (permalink) |
Freak Poster Join Date: Sep 2009 Location: www.telefony-nawigacje.pl
Member: 1122479 Status: Offline Thanks Meter: 22 | Chinese n97 Boot baudrate problem i have today "n97" i can't connect, i changed speed and computer, also i have two boxes and still nothing please help me COM4 [VCP0] selected module v3.21 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 12 sec Remove/Install battery now ! |
09-02-2010, 22:50 | #3 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 950629 Status: Offline Thanks Meter: 105 | I also had this problem with some phones.. Do following.. 100% Tested and Working solution for this Problem 1. Give power to the phone(VPP and GND)and connect to the box. 2. Connect a Wire to phone GND(-) and catch it's other end. now you must feel some current on your hand.(earth-current) 2.Run Chinese miracle soft and keep pressing power button Until Whole operation end. Tested by me many TIMES......... GD Luck.. |
The Following User Says Thank You to mswmkm For This Useful Post: |
09-04-2010, 17:03 | #8 (permalink) |
Member: 950629 Status: Offline Thanks Meter: 105 | So.. Try this.. 1. disassemble the phone and get the PCB out. 2. connect phone to infinity box and give power to the phone(it is good to use on board RX/TX point) 3. Run the software. 4. Find "power on" test point on the PCB and connect it to the phone ground using twister tool.(keep doing this until the operation end) 5. If not boot, it is a CPU faulty. try to reheat the CPU. |
09-04-2010, 22:19 | #9 (permalink) |
Member: 1122479 Status: Offline Thanks Meter: 22 | it's not a nand , same error mswmkm what's mean twister tool? i used tp on board because there is no rx,tx signal on mico usb. i have on board vpp,rx,tx,power and i acd3 ord adc3 something like that... |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
