06-18-2009, 12:16 | #1 (permalink) |
Freak Poster Join Date: Feb 2009 Location: Sabia >Gizan>KSA
Member: 978854 Status: Offline Thanks Meter: 33 | CLUB 95 ...calibration problem I have CLUB 95 ..after formating it stays on calibration ...but the touch screen is broken ...further tried to "Calibrate touchscreen" using MODE 1,,2,,3 ...i m using Chinese Miracle v2.83. MODE 1 calibration log ---------------------------------------------------------------- COM3 [VCP0] selected module v2.83 Action: touchscreen calibration mode: 1 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:4703:0005 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: BB13_BLE_L7EN_204_080313_HRILI9320_SIV0_TO75_CTF_B T_FM Version: BET25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 35416530158732 connection Ok detecting structure #5 (mode-1)... 0 1 2 3 done 158 byte(s) read reading data #2... writing data... verification... verification Ok Power-On and test phone now If calibration is not completed yet: 1. make "Reverse calibration order" Checked and try again 2. try another calibration mode Finished, time used: 14 sec Remove/Install battery now ! Checked but Not solved problem MODE 2 calibration log --------------------------------------------------------------------- COM3 [VCP0] selected module v2.83 Action: touchscreen calibration mode: 2 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:4703:0005 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: BB13_BLE_L7EN_204_080313_HRILI9320_SIV0_TO75_CTF_B T_FM Version: BET25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 35416530158732 connection Ok detecting structure #5 (mode-2)... 0warning: wrong packet cs 1warning: wrong packet cs 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19error: detection failed (20 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 58 sec Remove/Install battery now ! Checked but Not solved problem MODE 3 calibration log --------------------------------------------------------------- COM3 [VCP0] selected module v2.83 Action: touchscreen calibration mode: 3 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:4703:0005 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: BB13_BLE_L7EN_204_080313_HRILI9320_SIV0_TO75_CTF_B T_FM Version: BET25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 35416530158732 connection Ok detecting structure #5 (mode-3)... 0 1 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19error: detection failed (19 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 100 sec Remove/Install battery now ! further i also tried make check on "Reverse Calibration Order" but no success... hope you are gono post some solution soon.... Thanks |
06-18-2009, 18:28 | #2 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
The Following User Says Thank You to deepakgarg For This Useful Post: |
06-20-2009, 14:25 | #3 (permalink) |
Member: 978854 Status: Offline Thanks Meter: 33 | Thanks.. bro... but its done ..with chinese Miracle v2.81... I had to uninstall the new InfinitySetupMain_v2.16a pack ....and install InfinitySetupMain_v2.15a and upgrade chinese miracle to v2.81... then it worked.... using MODE 2.. ...... Infinity team may need to fix Calibration...of touch screen...in future updates... |
club 95 after two ment bad cenect charger | drjaved_akhter | Chinese Models & Cloned Phones | 2 | 08-11-2009 21:14 |
Club 95 | Yasir Ali | Infinity-Box | 1 | 06-01-2009 22:11 |
Club 95 stuck on touch secreen celebrate | alamgarh | Infinity-Box | 6 | 05-26-2009 22:34 |
Club 95 | msashami | Infinity-Box | 1 | 03-04-2009 23:13 |
Dear friend i need club 95 flash file | aamirgsm | Infinity-Box | 1 | 09-16-2008 16:51 |
