11-30-2008, 18:03 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | CM is not Changing any IMEI of Bestel D5000+.. u added the "3 imei" option on the software... but after format ffs and before not changing any imei of this phone.. software shows new imei..but after restart the phone still same imei (0000000000 or old imei).. but with free software i can change the three imei at the same time... |
11-30-2008, 18:08 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, it is always good idea to post logs and explain what you have tried to do. Please, tell me: is it hard to make so ? Now read your own message and tell me: how is it possible to help you if you gives zero information about problem. Any answer ? |
11-30-2008, 18:17 | #4 (permalink) | |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
Code: Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E03 Hardware version: DEWAV25_GEMINI_HW Software version: E868_D5000+_L101" Software date: 2006.06.14 Barcode: MT012345678901234567 imei: 000000000000000 imei: 000000000000000 Finished, time used: 5 sec Power off phone now ! Imei 355XXXXXXX7855 already was repaired: 30.11.2008-14:34:31 Continue with this imei ? Action: imei Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E03 Hardware version: DEWAV25_GEMINI_HW Software version: E868_D5000+_L101" Software date: 2006.06.14 Barcode: MT012345678901234567 imei: 000000000000000 imei: 000000000000000 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei: 355XXXXXXX78557 verification Ok Finished, time used: 5 sec Power off phone now ! Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E03 Hardware version: DEWAV25_GEMINI_HW Software version: E868_D5000+_L101" Software date: 2006.06.14 Barcode: MT012345678901234567 imei: 3550XXXXXXX78557 imei: 000000000000000 Finished, time used: 4 sec Power off phone now ! imei: 3550XXXXXXX78557 -----> after rebooting phone imei is gone to "0000000000000000".. p.s. : i just tried only mode-1 "imei1 and imei2"..but i tried mode-3 for "imei3".. mode3 imei log.. Code: COM2 [VCP0] selected module v2.69 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "repair imei" imei write method: mode-3 imei write channel: imei #3 for triple sim CPU new imei: 352XXXXXX1103 Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:9303:000B boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: DEWAV25_GEMINI_PCB01_GPRS_MT6225_S00.E868_D5000+_L101.BIN ver. sw 2: E868_D5000+_L101, 00000000 ffs offset/size: 00E00000/00200000 detecting security area (code #2)... ................................................................................................................................ security area (code #2) is absent detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98004900000002:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[DEWAV25_GEMINI_PCB01_GPRS_MT6225_S00.E868_D5000+_L101.BIN]... warning: wrong cs at 0x00F69800, retry... read error recovered file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[DEWAV25_GEMINI_PCB01_GPRS_MT6225_S00.E868_D5000+_L101.BIN]_20081130-140438.B0E.bin flash: 98004900000002:18E59F00000000 Backup required data Done Patch required data ... imei is not detected ! What to do: 1. Power-On phone 2. wait 20-30 sec 3. Power-Off by "Power" button, don't remove battery ! 4. Repeat "repair imei" procedure again If imei can't be detected: 1. make "complete" ffs format 2. Power-On phone 3. wait 20-30 sec 4. Power-Off by "Power" button, don't remove battery ! 5. Repeat "repair imei" procedure again If imei can't be detected: read flash and send to support: [email protected] Patch required data Fail Finished, time used: 166 sec Remove/Install battery now ! | |
The Following User Says Thank You to LoveLess For This Useful Post: |
I cant change the IMEI of a 6230i, is it normal? | puntodecontrol | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 12-16-2009 17:40 |
The version 2.16 of the ubl does not change the imei of them v3r with version of soft | joan rodriguez | Ultima Box Light | 5 | 07-13-2007 22:59 |
change the imei of 6101 with the new functions of RPL's? | ariphone | Universalbox | 2 | 07-24-2006 01:54 |
how can i change the imei of mars | darkeye | Mitsubishi | 10 | 08-16-2004 19:49 |
How can I change the IMEI of an Nokia 8850 | Killer81 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 07-10-2000 15:19 |
