02-02-2011, 14:50 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: in my h.d.d
Member: 252178 Status: Offline Sonork: 100.1582561 Thanks Meter: 123 | Cpu: Mt00c3 cable type: 1x12 (L12C) platform: MT: MT6205, MT6217-MT6235 searching adapter at COM8... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT00C3 result: Rx:12 Tx:11 time required: 60 sec Trying to Power-On... Power On ! Power On ! i can't read full flash COM8 [VCP1] selected module v3.26 Device: Autodetect 6253 NOR Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C1]: 00EC:240400000000 [SAMSUNG] K5N2833ATB chip size: 16Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: CREATONE.K015E_5_KW_E92_MULTI detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: CREATONE53_K015E_5_MULTI_PCB01_GPRS_MT6253_S00.CRE ATONE_K015E_5_KW_E92_MULTI.BIN project-id: CREATONE.K015E_5_KW_E92_MULTI, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done |
02-02-2011, 20:36 | #3 (permalink) |
Member: 252178 Status: Offline Sonork: 100.1582561 Thanks Meter: 123 | i can't read full flash COM8 [VCP1] selected module v3.26 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot Off chip: 0000:0000:000F status: FF high speed boot Off boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 17 sec Remove/Install battery now ! |
02-02-2011, 20:37 | #4 (permalink) |
Member: 252178 Status: Offline Sonork: 100.1582561 Thanks Meter: 123 | COM8 [VCP1] selected module v3.26 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot Off chip: 0000:0000:000F status: FF high speed boot Off boot packet size: 0400 error: bootcode load error: E8E8E59FC00EE08CC7ECE082E002E00C400CE1C1E004E18E40 1CE59DE004E08E3003E08EE8C8E59F300EE0833563E08CE00C E0034003E1C2E004E18E4020E59DE004E08E1001E08EE8A8E5 9F100EE0811CE1E083E003E0014001E1CCE004E18E4024E59D E004E08E2002E08EE888E59F200EE0422A62E081E001E00240 02E1C3E004E18E4028E59DE004E08EC00CE08ECCA4E24CC04F E24CC7ECE082E002E00C400CE1C1E004E18E402CE59DE004E0 8E3003E08EE844E59F300EE0433563E08CE00CE0034003E1C2 E004E18E4030E59DE004E08E1001E08EE824E59F100EE0811C E1E083E003E0014001E1CCE004E18E4034E59DE004E08E2002 E08EE804E59F200EE0422A62E081E001E0024002E1C3E004E1 8E4038E59DE004E08EC00CE08EE7E4E59FC00EE04CC7ECE082 E002E00C400CE1C1E004E18E403CE59DE004E08E3003E08EE7 C4E59F4002E1CC300EE0833563E08CE002E003E004E18E4004 E59DE004E08E1001E08EE7A4E59F400CE1C3100EE0811DE1E0 83E00CE001E004E18E4018E59DE004E08E2002E08EE784E59F 4003E1C1200EE0422BE2E081E003E002E004E18E402CE59DE0 04E08EC00CE08EE764E59F4001E1C2C00EE08CC96CE082E001 E00CE004E18E4000E59DE004E08E3003E08EE744E59F4002E1 CC300EE0833663E08CE002E003E004E18E4014E59DE004E08E 1001E08EE724E59F400CE1C3100EE0411DE1E083E00CE001E0 04E18E4028E59DE004E08E2002E08EE704E59F4003E1C1200E E0822BE2E081E003E002E004E18E403CE59DE004E08EC00CE0 8EE6E4E59F4001E1C2C00EE04CC96CE082E001E00CE004E18E 4010E59DE004E08E3003E08EE6C4E59F4002E1CC300EE04336 63E08CE002E003E004E1FEC00400004D573032 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... error: wrong answer: 09 error: wrong answer: 0B error: wrong answer: 3B : wrong answer after chip cfi request number of flash chip/regions detected: 00/01 flash chip is unknown or damaged. Fault reasons: 1. flash chip is damaged: replace or resolder/reball flash chip 2. hardware is damaged: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 19 sec Remove/Install battery now ! |
02-03-2011, 11:17 | #6 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Hungary Age: 48
Member: 141809 Status: Offline Thanks Meter: 30 | Error read flash N97C I also had a similar error N97C [CPU: 6225 MT] Another tool, unfortunately I could only read from the flash Here is the log of the error: COM5 [VCP0] selected module v3.26 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:7403:0004 status: FF high speed boot Off boot packet size: 0400 error: bootcode load error: FFFFEAFF0000E10F10C0E3A00001E180F000E12FD010E59F10 00E3A00001E3A00014EB000835EB00FFFDEAFF60004000009C E59F0000E5900014E590FF1EE12F008CE59F0000E5900018E5 90FF1EE12F107CE59F1000E5911010E5910100E791FF1EE12F 1068E59F1000E591100CE5910100E791FF1EE12F4030E92D30 54E59F004CE59F3000E58000F6EB005000E1A000FEEB006000 E1A0303CE59F0005EA004004E5930005E15440080593000601 5400040A00301CE2834000E5D30020E354FFF61AFF0001EA00 0004E59F3000E5808030E8BD14F440001514400014F8400000 00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFF0000000000000000000000000000000000000000000000 000000FFFFFFFFFFFFFFFFFFFF000000000000000000000000 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFF00010000006880010070800100788001004080010048 800100508001005880010024801300000000 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... error : no any expected answer : wrong answer after chip cfi request number of flash chip/regions detected: 00/01 flash chip is unknown or damaged. Fault reasons: 1. flash chip is damaged: replace or resolder/reball flash chip 2. hardware is damaged: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 34 sec Remove/Install battery now ! |
CPU: MT346C not supported yet! | asadnow2k | Infinity-Box | 45 | 05-10-2011 01:09 |
how to formate this CPU: MT346C with infinity | shakeel145 | Infinity-Box | 18 | 03-08-2011 10:23 |
China phone CPU: MT6205 format ffs error: wrong answer | layek_khan | Infinity-Box | 2 | 05-02-2010 19:36 |
CPU: MT6229 no support yet ? | Vansy | Infinity-Box | 0 | 10-10-2009 11:47 |
CPU: MT6223 is Supported by Multi-box ? | freeman2001 | Multi-Box | 1 | 11-04-2008 13:30 |
