10-02-2010, 08:59 | #1 (permalink) |
Product Supporter Join Date: Jun 2008 Location: TURBHE JANTA MARKETNAVI MUMBAI Age: 45
Member: 787829 Status: Offline Sonork: 100.1615114 Thanks Meter: 917 | Cpu: Mt346c high speed boot On error: hardware is not supported: [0000346C:00000001] Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 4 sec Remove/Install battery now ! SIR I HAVE DOWN LOAD LATEST CHINESMIRACLE AND GOING TO EDIT IMEI BUT IT SHOWS THIS WHATS THE PROBLEM AND WHEN YOU WILL GIVE UPDATE FOR THIS PROBLEM HELP PLSSSSS SIR HELP IN MCN BOX IT SUPPORT FROM LONG TIME WHY YOU CANNOT IWANT TO SEE THIS SOLUTION IN OUR INFINITY BOX NOT TO ANOTHER BOX FIRST BECAUSE WE ARE DEPENDING ON OUR INFINITY BOX NO TO OTHER SO PLSSSSSS Last edited by .::jagdeep-Gupta::.; 10-02-2010 at 09:06. |
10-02-2010, 09:53 | #3 (permalink) |
Member: 787829 Status: Offline Sonork: 100.1615114 Thanks Meter: 917 | Cpu: Mt346c COM6 [VCP0] selected module v3.24 Action: "repair imei" imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 352009023320042 Model: Autodetect 6228-6239 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [346C:0001]... CPU: MT346C high speed boot On error: hardware is not supported: [0000346C:00000001] Can not initialize test mode, possible reasons: 1. communication fault, repeat required operation 2. ffs/eeprom is seriously damaged, use repair ffs/eeprom files or use another unlock/format method error: operation failed ! Finished, time used: 6 sec Remove/Install battery now ! BROTHER THE PROBLEM IS SAME I THINK THIS CPU NOT SUPPOR IN THIS VERSION SO PLS INFINITY TEAM GIVE UPDATE TO THIS CPU |
10-23-2010, 23:51 | #6 (permalink) |
Member: 1043909 Status: Online Thanks Meter: 60,926 | We are waiting for test reports and comments here: http://forum.gsmhosting.com/vbb/f425...ments-1123803/ |
CPU: MT346C not supported yet! | asadnow2k | Infinity-Box | 45 | 05-10-2011 01:09 |
how to formate this CPU: MT346C with infinity | shakeel145 | Infinity-Box | 18 | 03-08-2011 10:23 |
China phone CPU: MT6205 format ffs error: wrong answer | layek_khan | Infinity-Box | 2 | 05-02-2010 19:36 |
CPU: MT6229 no support yet ? | Vansy | Infinity-Box | 0 | 10-10-2009 11:47 |
CPU: MT6223 is Supported by Multi-box ? | freeman2001 | Multi-Box | 1 | 11-04-2008 13:30 |
