09-21-2010, 21:24 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: PANGANDARAN BEACH Age: 44
Member: 427685 Status: Offline Thanks Meter: 103 | CPU: MT346C not supported yetMT346C cable type: 1x5 (L5A) platform: MT: MT62xx (autodetect) searching adapter at COM3... adapter found, version: 2000 pins: 5, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT346C result: Rx:4 Tx:2 time required: 7 sec Trying to Power-On... Power On ! saved: ht-g20 COM3 [VCP0] selected module v3.22 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [346C:0001]... CPU: MT346C high speed boot Off error: hardware is not supported: [0000346C:00000001] Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 7 sec Remove/Install battery now ! hope give new update |
09-21-2010, 23:10 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! this is new CPU type MT6253 you can read out flash selecting NAND CPU type. IMEI change is supported, format FFS and flash write- not we are working under this problem, support will be released soon |
09-22-2010, 08:50 | #3 (permalink) | |
Member: 427685 Status: Offline Thanks Meter: 103 | Quote:
cable type: 1x5 (L5A) platform: MT: MT62xx (autodetect) searching adapter at COM3... adapter found, version: 2000 pins: 5, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT346C result: Rx:4 Tx:2 time required: 7 sec COM3 selected module v3.22 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C1]: 00EC:240400000000 [SAMSUNG] K5N2833ATB chip size: 16Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done interesting cpu type found: 6253:8A02:8A00 ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: X19_HT_B_SS_MLA_06S0804 detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: RATECH53_09A_PCB01_GPRS_MT6253_S00.X19_HT_B_SS_MLA _06S0804.BIN_FLNK5N2866ATD_BQ12 project-id: X19_HT_B_SS_MLA_06S0804, 00000000 code offset: 00000000 ffs offset/size [02]: 00F00000/00100000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.22, database date: 02.09.2010): RATECH53_09A_PCB01_GPRS_MT6253_S00.X19_HT_B_SS_MLA _06S0804.BIN_FLNK5N2866ATD_BQ12 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 15Mb number of areas/bytes to read: 1:00F00000 reading (HW_STORAGE_NOR)... file saved: C:\Documents and Settings\RUBY\My Documents\RATECH53_09A_PCB01_GPRS_MT6253_S00.X19_H T_B_SS_MLA_06S0804.BIN_FLNK5N2866ATD_BQ12__firmwar e_20100922-144212.B0M.bin Disconnect... done Finished, time used: 8 min 0 sec Remove/Install battery now ! COM3 selected module v3.22 Action: reset settings ("format ffs") Model: Autodetect 6228-6239 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [346C:0001]... CPU: MT346C high speed boot On error: hardware is not supported: [0000346C:00000001] Can not initialize test mode, possible reasons: 1. communication fault, repeat required operation 2. ffs/eeprom is seriously damaged, use repair ffs/eeprom files or use another unlock/format method error: operation failed ! Finished, time used: 4 sec Remove/Install battery now !can not format,,,thank for ur support ,we are waitting mode | |
10-23-2010, 23:53 | #5 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | We are waiting for test reports and comments here: http://forum.gsmhosting.com/vbb/f425...ments-1123803/ |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Nokia 5110 - "SIMcard not accepted". | Kond | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-02-2000 22:46 |
winlock wintesla m2bus do not work | Bigbrothers2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2000 14:31 |
