03-08-2011, 07:35 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Cpu MT6253 Supported Or Not module v3.27 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 15 sec Remove/Install battery now ! |
03-08-2011, 07:54 | #3 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
It's supported for every function, look here- http://forum.gsmhosting.com/vbb/f425...-77-a-1216121/ Just select "Autodetect 6253 NOR" option in Model tab on "Settings" page. Wr. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
03-08-2011, 13:29 | #5 (permalink) |
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | still not working after select same cpu COM4 [VCP0] selected module v3.27 Device: Autodetect 6253 NOR Checking data, wait... advanced flash detection disabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 16 sec Remove/Install battery now ! |
03-08-2011, 13:37 | #7 (permalink) |
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | problem solved thanks COM4 [VCP0] selected module v3.27 Device: Autodetect 6253 NOR Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00020000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: G706G13R05XT8MLOV7670ML101215 detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: GAOPHONE53_12832_09A_PCB01_GPRS_MT6253_S00.G706G13 R05XT8MLOV7670ML101215.BIN project-id: G706G13R05XT8MLOV7670ML101215, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.27, database date: 03.03.2011): GAOPHONE53_12832_09A_PCB01_GPRS_MT6253_S00.G706G13 R05XT8MLOV7670ML101215.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== Format... Disconnect... done Finished, time used: 1 min 25 sec Remove/Install battery now ! |
The Following User Says Thank You to alamgarh For This Useful Post: |
03-08-2011, 13:40 | #8 (permalink) | |
Select model Huawei-G6620 and try again with latest MModule. And check with option "read/check information" or "Read detailed information". Post result. Wr. | |
03-13-2011, 09:31 | #9 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Chishinau,Moldova Age: 46
Member: 38921 Status: Offline Thanks Meter: 16 | for me,not working... COM4 [VCP0] selected module v3.27 Device: Autodetect 6253 NOR Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 0.0/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D chip size: 0Mb otp status/size: S_DONE/00000000 NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C chip size: 0Mb page/spare size: 0000/0000 pages per block: 0000 bits i/o: 00 address cycles: 00 internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 error: can not boot device: 07D4:S_BROM_DOWNLOAD_DA_FAIL error: last error: 07D4:S_BROM_DOWNLOAD_DA_FAIL Disconnect... done Finished, time used: 34 sec Remove/Install battery now ! |
03-13-2011, 10:00 | #10 (permalink) | |
Wr. | |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
GID1 for Germany D2 or Viag | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-21-1999 21:04 |
ORIGINAL SOFTWARE FOR SALE OR TRADE !!!!!!!!!!!!!!!!! | andrew bennett | Main Sales Section | 1 | 07-27-1999 21:31 |
