Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > Chinese Miracle & PinFinder
Old 09-21-2010, 11:14   #1 (permalink)
Member: 383211
CRTEL c200 dead need firmware and eeprom
CRTEL c200 dead need firmware and eeprom i try to find on suport erea but found only this file "flashfiles/ChineseMiracle/_MT6225/S200DJCRD3_PCB01_GPRS_MT6225_S00.S200DJCRD3_3EA0_V 1_0_0__G`Right-6700_16m_En_Ru_Fr_Es_It_De_Id_Tr_Farsi_Pt_Ar.B0M.b in"i m not try this file .plz give me its eeprom i thing eeprom is demaged.an firmware also thanks
COM31 [VCP0] selected
module v3.22
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:B903:0000
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 2088C4FFFF0043:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F099C418F098C018F098C018F093C4
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (05)
TCL-ID is absent
rom info detection finished
rom info ver: 05
sw version: S200DJCRD1_PCB01_GPRS_MT6225_S00.S200DJCRD1_3EA0_V 1_0_1.BIN
project-id: S200DJCRD1_3EA0_V1_0_1, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00080000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 1 min 16 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 09-21-2010, 22:51   #2 (permalink)
Member: 148515
hello!
must be very rare or new firmware.
unfortunately we dont have it in our collection.
you can try to search for same working phone on local market.
read out full backup and use it for flashing your faulty phone.
also i can convert to infinity format BIN file, if you find it.
Old 09-23-2011, 12:34   #3 (permalink)
Member: 177238
Question
module v3.22
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is absent
rom info ver: 05
TCL-ID is absent
ffs/eeprom chip: 00
====> Write ...
Write Done
ffs formatting...
Finalization Done
did u remember pinout (rx & tx) for this phone? my pinfinder couldn't find rx-tx
Old 09-23-2011, 13:01   #4 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
If you can't find rx-tx through pinfinder then open phone and find rx-tx on pcb.
Wr.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 10-27-2011, 15:28   #5 (permalink)
Member: 177238
Smile
Wr.
I founded rx/tx with PinFinder 5rx 4tx
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-15-2011 12:08
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 1 06-02-1999 16:23
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 05-26-1999 11:35
Page generated in 0.28217 seconds with 11 queries
