Old 03-13-2009, 04:14   #1 (permalink)
Registered User
Member: 511520
Sonork: 100.1573642
Thanks Meter: 127
Thumbs up dead china mobile via format
hi
i receieve i china mobile with restart problem with sim
i did format to it but after complet format it dead i try many time format but it still dead
i search its flash file in supoort area but not found in support
now i read fullflash from dead mobile
its model name is zt998
help me
Old 03-13-2009, 04:47   #2 (permalink)
Registered User
Member: 511520
Sonork: 100.1573642
Thanks Meter: 127
http://rapidshare.com/files/20859324...3.B0M.bin.html
Old 03-13-2009, 04:51   #3 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
pls post log with screen shot..
The Following User Says Thank You to venuno For This Useful Post:
Old 03-13-2009, 08:37   #4 (permalink)
Registered User
Member: 511520
Sonork: 100.1573642
Thanks Meter: 127
==== log opened: [3/12/2009 3:42:16 PM] ====
Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e
Loading data, wait...
[Infinity Box] v2.77
S/N: 0B7C:0112
Wait...
Device: Autodetect 6205-6227 NOR
Done
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
==== log: [3/12/2009 3:42:26 PM] ====
COM3 [VCP0] selected
module v2.77
Checking data, wait...
Action: "format ffs"
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:FC03:000B
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
New firmware detected (v.2.77, database date: 25.02.2009):
PBMTK25_GEMINI_PCB01_GPRS_MT6225_S00.T228DY_GKX_0_ 3.BIN
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send flash backup files to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
identification#1 protocol ver: 04
ver. sw 1: PBMTK25_GEMINI_PCB01_GPRS_MT6225_S00.T228DY_GKX_0_ 3.BIN
ver. sw 2: T228DY.GKX.0.3, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: eeprom[PBMTK25_GEMINI_PCB01_GPRS_MT6225_S00.T228DY_GKX_0_ 3.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[PBMTK25_GEMINI_PCB01_GPRS_MT6225_S00.T228DY_GKX_0_ 3.BIN]_20090312-154446.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 140 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following User Says Thank You to dhawan_boss007 For This Useful Post:
Old 03-13-2009, 08:40   #5 (permalink)
Registered User
Member: 511520
Sonork: 100.1573642
Thanks Meter: 127
==== log: [3/12/2009 3:49:48 PM] ====
module v2.77
Action: read NOR flash
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
ffs/eeprom chip: 00
reading: flash[PBMTK25_GEMINI_PCB01_GPRS_MT6225_S00.T228DY_GKX_0_ 3.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\flash[PBMTK25_GEMINI_PCB01_GPRS_MT6225_S00.T228DY_GKX_0_ 3.BIN]_20090312-160113.B0M.bin
Finished, time used: 772 sec
smart-card disconnected
Old 03-13-2009, 08:54   #6 (permalink)
ogc
Registered User
Member: 52073
Thanks Meter: 6
just maybe...
try to hold on for more than 1 min power button.
The Following User Says Thank You to ogc For This Useful Post:
Old 03-14-2009, 08:28   #7 (permalink)
Registered User
Member: 511520
Sonork: 100.1573642
Thanks Meter: 127
same position brother help me
Old 03-14-2009, 09:39   #8 (permalink)
gsmkiller173's Avatar
Member: 209582
Sonork: 100.1607015
Thanks Meter: 149
rehot flas and main cpu then flash it again
with this file
Old 03-14-2009, 11:16   #9 (permalink)
saifali's Avatar
Member: 772820
Sonork: BE MASTERMIND
Thanks Meter: 124
u need to rehot mtk and flash it will on if no luck just research flash files in support
Old 03-17-2009, 12:49   #10 (permalink)
Registered User
Member: 511520
Sonork: 100.1573642
Thanks Meter: 127
have anybody its flashfile
Old 03-18-2009, 07:38   #11 (permalink)
saifali's Avatar
Member: 772820
Thanks Meter: 124
dear look an other same set and read from it and flash it on ur dead set
Old 03-18-2009, 20:59   #12 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
hi.. i think ur backup is damaged.. it is 5.7 mb.. u need working and fine backup...
Old 03-21-2009, 06:45   #13 (permalink)
Registered User
Member: 511520
Sonork: 100.1573642
Thanks Meter: 127
thanx mate i will search and piost the result sooooon
Old 03-21-2009, 14:45   #14 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,421
Please give me pinout for it
Faisal_Computer
china mobile flashing formatting ajit bs Infinity-Box 1 03-28-2010 17:04
china mobile flashing formatting ajit bs Chinese Models & Cloned Phones 0 03-28-2010 16:54
CHINA MOBILE VEDIO FORMAT .moa Convert Soft gopalhot Chinese Models & Cloned Phones 0 06-19-2008 18:13
How I Servive My Dead China Mobile dil_PAKISTANI Infinity-Box 3 01-24-2008 16:08
Page generated in 0.25308 seconds with 9 queries
