Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > Chinese Miracle & PinFinder
Old 02-14-2008, 16:40   #1 (permalink)
ashok_kumar459's Avatar
Member: 202500
Dead China N95 Slider And Etc.... Hw To Find Flash File Help Pl.......
Dear infinity and china repairer please need solution for finding correct flash file from supoort site because there are one flash file name so many files are there. unable to verify. downloaded file after flash become white lcd on screen. need 100% correct file to select how...........? please need detail solution.
thanks in advance
Old 02-14-2008, 22:24   #2 (permalink)
Member: 148515
hello!
to get right flash file from support you must read original phone version at beggining.
like it was done here: dst01 death please
in your case you can not read firmware version because you already overwrite it with wrong flash files.
what to do: go to folder where is located Chinese miracle.
open file named "operation.log"
look for first operation which you did with this phone (you can find it by date/time).
post this part of log here, we will advice flash file
Old 02-15-2008, 05:24   #3 (permalink)
Member: 263005
find a good same set (hardware) read full flash and write to the dead set I try to several handset lukly all set is alive
Old 02-15-2008, 06:33   #4 (permalink)
REMO's Avatar
Member: 49339
search sticky theards.
Old 02-15-2008, 13:00   #5 (permalink)
Member: 148515
hello guys!
i still insist htat easyer way for him is to find in log file ORIGINAL VERSION of this phone.
then we will advice him a flash file
Old 02-18-2008, 20:37   #6 (permalink)
HakkanR's Avatar
Member: 40460
i have same problem.. My phone is power on good, open Sound ok.. but no screen (white screen) i try a lot of versiyons
my phone N95 8gb Black Bord vers. c300 v1.0 CPUmt6226ba myt first detailed information are here : (before flashing!)
Action: read/check detailed information
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
chip: 0031:75F8:B83F
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:2CEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 Ok
security area backup saved: id.8861808C.[N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32.B IN_E18EF9B1].rpl
New firmware detected:
Thanks For Advance
Old 02-18-2008, 23:23   #7 (permalink)
Member: 148515
hello mr. HakkanR!
try this files:
flashfiles/ChineseMiracle/_MT6226/noname/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32_1 6m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6226/CM_Nokia-N95_N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V 32_16m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar.B0M.bin
Old 02-19-2008, 12:36   #8 (permalink)
HakkanR's Avatar
Member: 40460
Mr. InfinityHelp
Thank You for your answer fast!
i try both file, Flashing successufull but no screen again.
my first system bakcup file on Attach. (from first Flashing)
my flashing settings are
Autodetect 6205-6227 NOR (2.28 Chinese Miracle)
Backup System Area Checked
Advanced Chip Detection method Checked
Find firmware Version not checked
Find Language Names not checked
Boot boudrate autoselect Checked
Boot Packed Size 1024
Fix Security during flash Checked
Enchanced Security fix method not checked
Disable Warnings not checked
SmartWrite not checked!
Load Firmware, Select Flash file which you write name prev msg.
and press Write plug cable put battery
When software press and hold Pwer button.. i press power button.
boot ok..
When software release power button, i release power button..
Last Lines Flash operation are :
Write: Firmware
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
Write Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _8861808C_N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_0 4_MP_V32.BIN_604DFD9B_20080219-143201.B0X.bin
Finished, time used: 403 sec
Remove/Install battery now !
Thank for advance.
Old 03-08-2008, 00:07   #9 (permalink)
Member: 49066
hi;
its hardware probleme, change the flex ruban.
good day.
Old 03-08-2008, 00:17   #10 (permalink)
Member: 56090
Originally Posted by nefhamid View Post
hi;
good day.
I think no and i'm sure problem is soft, proper flashfile is not uploaded, try other flash and don't forget NorFlash
SAMSUNG K5L2731CAM
SAMSUNG K5L2931CAM
SPANSION S71PL127N
SPANSION S71PL129N
I remember that i have flashed 15 times until succeed to revive one N95, good luck for you
Salam
Old 03-08-2008, 00:22   #11 (permalink)
HakkanR's Avatar
Member: 40460
is this a contrast problem ? China Phones have Contrast Tool ?
beacuse i flash a lot of file.. always phone power-on, startup sound ok.. phone work good.. but no display. i get crazy
Old 03-08-2008, 00:41   #12 (permalink)
InfinitySupport's Avatar
Member: 130995
@abdoune
Probably you will be surpriced... but flash chip type has no relation with LCD...
Also, Samsung and Spansion flash chip types is absolutely similar (I mean internal operations) so there is no any reason to try "this Spansion", "that Samsung", "one more Spanison", "another one Samsung".
The main criteria is a FIRMWARE VERSION name !
@HakkanR
Also in some cases smart Chinese people is "little bit" lazy, so they even don't change firmware version name for different firmware, so even if you have several files with absolutely the same firmware version name there is a reason to try all of them.
Yes, I understand that it's need to spend a lot of time to find suitable firmware, ut there is no any other way, even Chinese engineers has zero information about their super phones, so nobody can give you 100% real information, need to try, try again, try again and again.
Old 03-08-2008, 09:59   #13 (permalink)
Member: 56090
@HakkanR describe to us what you show in phone ? is it N95 Bluetooth displayed in the face of the phone or simply N95 or NOKlA N95, is it writen under battery Rm17
Salam
Old 03-08-2008, 11:46   #14 (permalink)
HakkanR's Avatar
Member: 40460
@abdoune Rm-17 Right, Black Double Slider, N95 8GB 6226BA Processor and samsung 32mb flash, c300 board version. (Dark Yellow board, nearest Blue. same e250 2nd edition 250d) and imei start 358.... and Made by Nokia write. Single Sim.
Old 03-08-2008, 17:29   #15 (permalink)
Member: 56090
Ok wait i will upload flashfile for you just wait, we will incha al lah repair the handset
Salam
How to find flash file for china dead handsets phone2world Chinese Models & Cloned Phones 7 11-02-2008 15:47
need very fast help to find flash file for nokia E50-1 by nokia code:0033036 tsarkh Universalbox 5 05-06-2007 15:54
where to find flash file for mars lo1 and lo3 monti_908 Mitsubishi 0 03-21-2003 08:29
Who can send me or help me to find flash file for GD70 v22A or similar??? starpho Panasonic 0 10-11-2001 03:10
Who can send me or help me to find flash file for GD70 v22A or similar??? starpho Panasonic 0 10-05-2001 02:38
Page generated in 1.56752 seconds with 12 queries
