Old 05-21-2011, 06:58   #1 (permalink)
nilesh_patel717's Avatar
Member: 596791
Thanks Meter: 37
dead by formatting
i have china alfatel h1 phone working fine i complete format phone phone dead
i flash with new flash file phone still dead log is hear
board id huscky-v7.0
LOG
COM9 [VCP0] selected
module v3.26
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: write flash
"smart write" active
write: Firmware
HUSCKY7_S60_18V_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_242_YYMMDD_CAM_MCPMCP_O__Alfatel-H1A_16m_En_Ru_Fr_Hi.B0M.bin
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
HUSCKY7_S60_18V_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_242_YYMMDD_CAM_MCPMCP_O__ffs_01.B0E. bin
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:6603:0000
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC240200000000:18E59F00000000
flash: Samsung K5L2833ATA T 16Mb
otp offset: 00FF0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
slowest
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [protected] type (04), 1 record(s)
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.D124BE46.[HUSCKY7_S60_18V_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_242_YYMMDD_CAM_MCPMCP_O.BIN_CABEE31B].rpl
rom info detection finished
device-id: D124BE46
rom info ver: 04
sw version: HUSCKY7_S60_18V_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_242_YYMMDD_CAM_MCPMCP_O.BIN
project-id: PN-SC_CN_LLNUMLD_242_YYMMDD_CAM_MCPMCP_O, 1BE3BECA
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
startup code area #1 calculation...
startup code area #1 fixed
detecting startup code area #2...
startup code area #2 is absent
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\H USCKY7_S60_18V_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_242_YYMMDD_CAM_MCPMCP_O__system_log_ D124BE46_CABEE31B_20110521-105457.B0X.bin
Area: Firmware
Write: Firmware
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
====> Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\H USCKY7_S60_18V_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_242_YYMMDD_CAM_MCPMCP_O__system_log_ D124BE46_CABEE31B_20110521-111445.B0X.bin
Finished, time used: 21 min 28 sec
Remove/Install battery now !
Old 05-21-2011, 08:33   #2 (permalink)
Member: 1092450
Thanks Meter: 196
re write the file your problem will bee 100 sure
Old 05-21-2011, 12:03   #3 (permalink)
Member: 596791
Thanks Meter: 37
rewrite which file eeprom or firmware
Old 05-21-2011, 12:05   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
which was phone's original software version? you can find it in operation.log file.
open it with notepad and scroll it up from the end. search for first format operation.
there you will see original software version. Compare it will flash file you used for flashing. Please remember that difference even 1 digit can cause dead phone
Old 05-21-2011, 12:13   #5 (permalink)
ORANGE MOB's Avatar
Member: 1549240
Thanks Meter: 1,130
pls check your flash file and match original back up file if any difference btw original backup and your new flash file then phone cant power on need same file with original backup
Old 05-21-2011, 14:11   #6 (permalink)
Member: 36878
Thanks Meter: 23
here is link for flash file u ask
Index of ./download/flash-files/china/
I have 5.28 unlocker by cable. GreEn Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 15 07-13-2000 21:57
5.28 working solution by eeprom 24x16 SLO/EU Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 06-22-2000 15:55
nokia nse-spv8 by zulea rothmanns Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-12-2000 07:52
have nokia lock 2 solution by cable oskarcore Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-29-1999 22:49
Page generated in 0.22476 seconds with 9 queries
