Old 02-01-2010, 12:45   #1 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
E66 nokia need flash file no flash file in support
pleas add flashing E66 nokia china phone after format phone totally dead
COM8 [VCP3] selected
module v3.06
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write flash
"smart write" active
write: Firmware
_fullflash_20100201-180232.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:5203:0003
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC257E25082501:18A59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
460800
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: _ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\E66\_ffs_20100201-180824.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Code CRC check error fix...
firmware do not have "Code CRC check error" area
Special operation Done
====> Write ...
- damaged firmware
ffs/eeprom address can not be detected, value from database assigned: 00E00000/00200000
sec info (fast) detection...
usb bootloader (file) is absent
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 2 min 23 sec
Remove/Install battery now !
TORSTAR25_GEMINI_PCB01_GPRS_MT6225_S00.TORSTAR_VER _1_03_NK__ffs...
Old 02-01-2010, 12:51   #2 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
need this file no file available this........................
Old 02-01-2010, 16:47   #3 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,421
Hello,
If required file can not be found in support area (please use "search" function in support area first)
it will be good if somebody can read full flash from the same good working phone and send
full flash backup to [email protected] so we will be able to prepare and upload
good working files in support area for all users.
Here is an instruction how to make "search" in support area: http://forum.gsmhosting.com/vbb/showthread.php?t=499453
Please, DO NOT send to us backup files from damaged phones. We CAN NOT repair damaged files !
Faisal_Computer
Old 02-01-2010, 22:35   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
sorry, no such flash file in our coollection.
can you find same working phone on local market?
Old 02-02-2010, 03:35   #5 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
[QUOTE]hello!
can you find same working phone on local market?/QUOTE]
can you pleas tell me what is the same file for e66 nokia
Old 02-02-2010, 03:47   #6 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
what flash file compatible for E66 Chinese nokia pleas help
Old 02-02-2010, 03:59   #7 (permalink)
Member: 253726
Sonork: 100 1605478
Thanks Meter: 21
don't worry ,just arrive my other infinity box and pinfinder ,i have e66 chinese soon upload e66 chinese flash
Old 02-02-2010, 04:03   #8 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
after flash the phone steel dead i try used flash fie in support same but steel dead here in flash
COM8 [VCP0] selected
module v3.06
Action: write flash
write: Firmware
_ffs_20100202-102833.B0E.bin
skip: Customization
skip: Eeprom/ffs
====> Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
flash: EC257E25082501:FFFFFF00000000
flash: EC257E25082501:FFBFFF00000000
Initialize Done
====> Set baud ...
460800
Set baud Done
it's time to stop: FFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBF
- damaged firmware
checking area [00000000]: 00080000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
ffs/eeprom chip: 00
reading: _ffs...
Old 02-02-2010, 04:26   #9 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
module v3.06
Action: write flash
write: Firmware
TORSTAR25_GEMINI_PCB01_GPRS_MT6225_S00.TORSTAR_VER _1_03_NK__fullflash_20100201-192819.B0M.bin
skip: Customization
write: Eeprom/ffs
TORSTAR25_GEMINI_PCB01_GPRS_MT6225_S00.TORSTAR_VER _1_03_NK__ffs_20100201-185657.B0E.bin
====> Boot ...
19200 autodetect
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
460800
Set baud Done
Warning: probably flash chip is empty, erased, incorrectly flashed or damaged !
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
- damaged firmware
ffs/eeprom chip: 00
reading: _ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\_ffs_20100202-111029.B0E.bin
====> Write ...
- damaged firmware
startup code area #1 check...
startup code area #1 fixed
Area: Firmware
Write: Firmware
Area: Eeprom/ffs
flash: EC257E25082501:18E59F00000000
Write: Eeprom/ffs
Write Done
Finalization Done
Finished, time used: 16 min 58 sec
after flash now the phone not responding no power
Old 02-02-2010, 10:06   #10 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
module v3.08
Action: write flash
write: Firmware
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
otp offset: 00000000
Initialize Done
====> Set baud ...
460800
Set baud Done
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
New firmware detected (v.3.08, database date: 30.01.2010):
TORSTAR25_GEMINI_PCB01_GPRS_MT6225_S00.TORSTAR_VER _1_03_NK.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info ver: 04
sw version: TORSTAR25_GEMINI_PCB01_GPRS_MT6225_S00.TORSTAR_VER _1_03_NK.BIN
project-id: TORSTAR_VER_1.03_NK, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
standard ffs/eeprom offset detected: 00E00000
ffs/eeprom found near: 00E10000
Detected ffs/eeprom address is non-standard: 00E10000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
Are you sure that detected ffs/eeprom address is correct ?
standard ffs/eeprom address confirmed by user: 00E00000
ffs/eeprom chip: 00
reading: TORSTAR25_GEMINI_PCB01_GPRS_MT6225_S00.TORSTAR_VER _1_03_NK__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\TORSTAR25_GEMINI_ PCB01_GPRS_MT6225_S00.TORSTAR_VER_1_03_NK__ffs_201 00202-170358.B0E.bin
====> Write ...
Area: Firmware
Write: Firmware
Write Done
Finalization Done
Finished, time used: 3 min 20 sec
Old 02-02-2010, 10:07   #11 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
this is new pleas add this file is needed thank you
Old 02-07-2010, 01:51   #12 (permalink)
Member: 253726
Sonork: 100 1605478
Thanks Meter: 21
http://forum.gsmhosting.com/vbb/show...&highlight=e66
Need flash files for P910i, not in support!!! mayer SonyEricsson (USB-Smart) 8 06-09-2006 20:10
@@ v545 flash file is not available in support area@@ rajabrotherscom Smart-Clip 2 04-25-2006 12:36
why no *EMEA5* file for F500/k500 in support ? cellularman SonyEricsson (USB-Smart) 1 12-20-2005 12:51
J210i flash file not available yet in support area why???? ReyTech Cruiser Suite 2 12-12-2005 09:00
no flash files n sharp exe in support area ASHIF ThunderStorm Box 4 04-23-2005 02:59
Page generated in 0.29619 seconds with 9 queries
