Old 07-15-2010, 18:42   #1 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,181
e99i pinout by info_gsm
The Following User Says Thank You to MMDEBILI For This Useful Post:
Old 07-15-2010, 18:57   #2 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,181
COM4 [VCP0] selected
module v3.07
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "repair imei"
imei write channel: imei #1 (default imei inside firmware)
new imei: 358295003927096
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:9F03:0008
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98000300000001:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
New firmware detected (v.3.07, database date: 08.07.2010):
STANDARD_GEMINI_PCB01_GPRS_MT6225_S00.G107U3R058TO G14ML100120.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info ver: 04
sw version: STANDARD_GEMINI_PCB01_GPRS_MT6225_S00.G107U3R058TO G14ML100120.BIN
project-id: G107U3R058TOG14ML100120, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00080000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detecting startup code area #2...
startup code area #2 is absent
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
detecting ffs/eeprom structure pass 2...
detect standard ffs/eeprom location pass #1...
detect standard ffs/eeprom offset pass #1...
ffs/eeprom record offset detected
detect standard ffs/eeprom data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok element #2
imei default found: 13579024681122
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write: imei
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 5 min 32 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following 3 Users Say Thank You to MMDEBILI For This Useful Post:
Please Help, Pinout of N8810 mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 06-30-2010 15:53
nokia nse-spv8 by zulea rothmanns Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-12-2000 07:52
have nokia lock 2 solution by cable oskarcore Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-29-1999 22:49
Page generated in 0.19399 seconds with 10 queries
