Old 12-13-2008, 17:01   #1 (permalink)
Member: 127027
this erro can slved with infinity-box
fone restart after this operatinoCOM14 [VCP3] selected
module v2.70
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:0B03:000D
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
230400
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw 1: MTK25_GEMINI_PCB01_GPRS_MT6225_S00.A522-ZSPIDER_8G-2_G-CAM_MY_146_081014.BIN
ver. sw 2: A522-ZSPIDER_8G-2_G-CAM_MY_146_081014, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: eeprom[MTK25_GEMINI_PCB01_GPRS_MT6225_S00.A522-ZSPIDER_8G-2_G-CAM_MY_146_081014.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[MTK25_GEMINI_PCB01_GPRS_MT6225_S00.A522-ZSPIDER_8G-2_G-CAM_MY_146_081014.BIN]_20081213-185948.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 184 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 12-13-2008, 17:02   #2 (permalink)
Member: 127027
module v2.70
Action: reset settings
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6225
high speed boot On
Connecting, wait...
Phone detected, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: A522-ZSPIDER_8G-2_G-CAM_MY_146_081014
Version: MTK25_GEMINI_HW
detecting structure #2...
5 11 done
67 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
building list...
done
items to clear: 136
warning: wrong packet cs
items cleared: 136 of 136
building list...
done
items remains: 0
Finished, time used: 22 sec
Old 12-13-2008, 17:03   #3 (permalink)
Member: 127027
module v2.70
Action: read codes
unlock method: read codes
19200 autodetect
CPU: MT6225
high speed boot On
Connecting, wait...
Date: 2006.06.14
Version: 1.0
5 11 done
67 byte(s) read
connection Ok
detecting structure #1...
0warning: wrong packet cs
1 5 8 9 10 12 13 14 15 16 20 23 24 25 27 28 29error: detection failed (18 tries), read flash and send to support
error: can't read required data
error: operation failed !
Finished, time used: 16 sec
Old 12-13-2008, 17:04   #4 (permalink)
Member: 127027
module v2.70
Action: repair "bad software" (mode-1)
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
Boot Done
Initialize ...
Initialize Done
Set baud ...
230400
Set baud Done
detecting firmware protection...
detecting firmware structure #8...
phase #1...
phase #2...
done
error: firmware protection firmware structure #8 is not found
What to do:
1. Be sure that your phone really has "bad software" problem, in other case do NOT use "bad software" button !
2. Repeat "bad software" operation several times to avoid communication problems.
3. Flash phone with firmware from support area and repeat "bad software" operation.
If still no luck:
1. read full flash and send to support: [email protected]
2. send "operation.log" file to support: [email protected]
error: autodetection failed
Finished, time used: 51 sec
Old 12-13-2008, 17:07   #5 (permalink)
Member: 127027
module v2.70
Action: repair "bad software" (mode-2)
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
Boot Done
Initialize ...
Initialize Done
Set baud ...
230400
Set baud Done
phase #1...
phase #2...
done
What to do:
If still no luck:
Old 12-13-2008, 20:47   #6 (permalink)
Member: 148515
Thanks Meter: 19,531
hello!
what is phone current condition? restarting?
if all you did returned zero result- now flashing must be performaed.
sad thing is that we dont have this firmware in our support area collection.
can you find same working phone on local market?
readed from it backup would fix your faulty phone
Old 12-13-2008, 23:14   #7 (permalink)
Member: 127027
NO NO
my problem not for flash becuse i flash phone with another flash for good fone and maked format unlock >>>????? but fone restart and that not one fone have same problem
this name have problem
and maked format with spederman not sloved
Old 12-14-2008, 03:57   #8 (permalink)
yawarniazi's Avatar
Member: 194128
Thanks Meter: 303
Can you please be more detailed about your problem?
You said phone restarts, but you didn't told that how or when.
Phone restart when making calls? OR somewhere else?
Old 12-14-2008, 11:22   #9 (permalink)
Member: 127027
after input sim thanks for anser me
Old 12-15-2008, 19:49   #10 (permalink)
Member: 148515
hello!
please send to us backup readed from same working phone.
after we will process it- you will be able to reapir faulty phone.
sagem soft that can work with infinity box iduo success Universal GSM Software 1 05-21-2009 19:54
Help!!! Who Can Sell A Infinity Box With refa Infinity-Box 1 02-29-2008 16:14
J120 i can not be unlock with infinity box with last update leroi Infinity-Box 3 11-09-2007 11:12
When we can unlock W375 with Infinity-Box? stylius Infinity-Box 1 05-14-2007 09:03
can i unlock p341 with Infinity-Box elsokary Infinity-Box 2 08-27-2005 17:45
Page generated in 0.21222 seconds with 9 queries
