08-16-2010, 19:43 | #1 (permalink) |
Junior Member Join Date: Jan 2009
Member: 938391 Status: Offline Thanks Meter: 2 | Error message CPU:MT6235 Phone ( still ) 100% working Flash type: NAND -read full flash was ok, made backup. After changing language in flash file, try to upload to the phone, but got this error message: COM20 [VCP0] selected module v3.20 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: write flash NAND write: Firmware editor_corrected_L029_ML_PCB01_GPRS_MT6235B_S01.L0 29_ML_TY8_WF_GPS_TV_MT6601_V4_07__firmware_2010081 6-190600.B4M.bin.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... nfi scat area detected nfi area detection finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00D100900015 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: L029_ML_TY8_WF_GPS_TV_MT6601_V4.07 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: L029_ML_BOOTLOADER_V005_MT6235B_L029_ML_TY8_WF_GPS _TV_MT6601_V4_ nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: L029_ML_PCB01_GPRS_MT6235B_S01.L029_ML_TY8_WF_GPS_ TV_MT6601_V4_07.BIN project-id: L029_ML_TY8_WF_GPS_TV_MT6601_V4.07, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: 2nd [standard] type TCL-ID is absent ===> done ==================== New firmware detected (v.3.20, database date: 26.07.2010): L029_ML_PCB01_GPRS_MT6235B_S01.L029_ML_TY8_WF_GPS_ TV_MT6601_V4_07.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== nfi area detection... nfi scat area detected nfi area detection finished: Ok startup code area #1 check... error: done number of cores: 3 loading files... number of areas: 3 done write... error: can not write flash: 138F:S_FTHND_FILE_IS_NOT_LOADED_YET error: last error: 138F:S_FTHND_FILE_IS_NOT_LOADED_YET Disconnect... done Finished, time used: 3 min 17 sec Remove/Install battery now ! Pls help me, |
08-16-2010, 23:35 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hi, 1. check free HDD space, you have to have at least 1 Gb free space at C drive for temporary files. Try to flash phone again. 2. try to flash phone with original backup. What is the results ? |
08-17-2010, 18:56 | #3 (permalink) |
Member: 938391 Status: Offline Thanks Meter: 2 | I've tried on 2 different computers, one with XP other one with Vista, both have plenty of HDD space, but it was complete waste of time, ended with the same result. It seems Infinity box has a serious problem with NAND falsh equipped phones with MT6235. It's a fortune the phone wasn't bricked this time, like the last one I've reported - and Infinity Team didn't send me any useful advise or update so that phone is dead. If your product does not support these kind of phones, do not recommend any useless solution, cause it takes so long to test, just tell me it's not supported. |
08-17-2010, 19:38 | #4 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 950629 Status: Offline Thanks Meter: 105 | MT 6235 NAND flash supported by infinity. i already done few sets. It seems to be ur flash file damaged during it's changing. 1. try to use original backup file. 2. if sill same, make sure u have full access to the file. change it's name(except file extension) 3. change it's location(make another copy of that file to another location(like C:\, D:\ , E:\) and try it) 4. use good virus guard. |
09-01-2010, 08:49 | #5 (permalink) |
Member: 938391 Status: Offline Thanks Meter: 2 | There's a new case again: Reading firmware: COM20 [VCP0] selected module v3.20 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0005]: 00EC:0079005A003F [SAMSUNG] K9K1G08X0A chip size: 128Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 03000000/05000000 firmware size: 48Mb ffs size: 80Mb detect sec ro... detect custom parameters... detect project-id... project-id: LN233_HY_V1.0R detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: NEOTEL35_08B_GEMINI_BOOTLOADER_V005_MT6235B_LN233_ HY_V1_0R.bin nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.LN233_H Y_V1_0R--100403.BIN project-id: LN233_HY_V1.0R, 00000000 code offset: 00000000 ffs offset/size [01]: 03000000/05000000 rom info structure: 2nd [standard] type TCL-ID is absent ===> done ==================== New firmware detected (v.3.20, database date: 26.07.2010): NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.LN233_H Y_V1_0R--100403.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 48Mb number of areas/bytes to read: 1:03000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... file saved: C:\Program Files\InfinityBox\ChineseMiracle\NEOTEL35_08B_GEMI NI_PCB01_GPRS_MT6235B_S01.LN233_HY_V1_0R--100403__firmware_20100831-200150.B4M.bin Disconnect... done Finished, time used: 81 min 26 sec Remove/Install battery now ! Writing: COM20 [VCP0] selected module v3.20 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: write flash NAND write: Firmware editor_corrected_NEOTEL35_08B_GEMINI_PCB01_GPRS_MT 6235B_S01.LN233_HY_V1_0R--100403__firmware_20100831-200150.B4M.bin.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... nfi scat area detected nfi area detection finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0005]: 00EC:0079005A003F [SAMSUNG] K9K1G08X0A chip size: 128Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 03000000/05000000 firmware size: 48Mb ffs size: 80Mb detect sec ro... detect custom parameters... detect project-id... project-id: LN233_HY_V1.0R detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.LN233_H Y_V1_0R--100403.BIN project-id: LN233_HY_V1.0R, 00000000 code offset: 00000000 ffs offset/size [01]: 03000000/05000000 rom info structure: 2nd [standard] type TCL-ID is absent ===> done ==================== New firmware detected (v.3.20, database date: 26.07.2010): NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.LN233_H Y_V1_0R--100403.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== nfi area detection... nfi scat area detected nfi area detection finished: Ok startup code area #1 check... error: done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... error: can not write flash: 0FAE:S_FT_NFB_DOWNLOAD_BOOTLOADER_FAIL error: last error: 0FAE:S_FT_NFB_DOWNLOAD_BOOTLOADER_FAIL Disconnect... done Finished, time used: 54 sec Remove/Install battery now ! The result is another dead phone again! -Battery: 4,19V -Got plenty of HDD space -Tried original backup 10 times -Firmware reading/writing working 100% perfect with 6225+NOR on the same config. Infinity team please give me real support, this makes me a big loss in business. |
09-01-2010, 11:00 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, 1. try to use latest ChineseMiracle v3.21 (from support area) or this new software v3.22: http://www.infinity-box.com/download...acle_v3.22.rar Post here operation log. 2. if software ask to send files to support, please, do it doe to if we will check new firmware we will be able to add new features and new firmware support. |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
Avoid 3 times error code in Nokia 6185 | X-plot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-08-2000 20:24 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
