Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > Chinese Miracle & PinFinder
Old 06-19-2010, 15:43   #1 (permalink)
Member: 938391
Firmware write problem
I get this message below after I'm trying to write back the readed full flash to an i999 - iPhone like - mobile . Now the phone is dead, before the operation it was 100% OK. I've tried to change the langugage wit the latest version of LPE. It was the same error with the editor corrected firmware also. Please tell help how to fix the phone.
COM20 [VCP0] selected
module v3.15
Device: Autodetect 6228-6239 NAND
Checking data, wait...
Action: write flash NAND
write: Firmware
NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.LN233_H Y_V1_0R--100315__firmware_20100619-145422.B4M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
nfi area detection...
bootloader version: NEOTEL35_08B_GEMINI_BOOTLOADER_V005_MT6235B_LN233_ HY_V1_0R.bin
nfi area detection finished: Ok
interface: BROM_DLL_v3.1012.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0005]: 00EC:0079005A003F [SAMSUNG] K9K1G08X0A
chip size: 128Mb
page/spare size: 0200/0010
pages per block: 0020
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: absent
done
Set baudrate (115200)...
done
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 03000000/05000000
firmware size: 48Mb
ffs size: 80Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: LN233_HY_V1.0R
detect NAND info...
number of areas/bytes to read: 1:00034000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
warning: header is empty: probably flash chip completely erased
warning: can not detect header
nfi area detection finished: failed
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 07
sw version: NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.LN233_H Y_V1_0R--100315.BIN
project-id: LN233_HY_V1.0R, 00000000
code offset: 00000000
ffs offset/size [01]: 03000000/05000000
rom info structure: 2nd [standard] generation
TCL-ID is absent
===> done
New firmware detected (v.3.15, database date: 06.06.2010):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: mt62xx@gmail.com or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
startup code area #1 check...
startup code area #1 fixed
number of cores: 3
loading files...
number of areas: 3
done
write...
write bootloader...
error: can not write flash: 0FAE:S_FT_NFB_DOWNLOAD_BOOTLOADER_FAIL
error: last error: 0FAE:S_FT_NFB_DOWNLOAD_BOOTLOADER_FAIL
Disconnect...
done
Finished, time used: 55 sec
Remove/Install battery now !
Thanks for your help in advance
Old 06-20-2010, 18:42   #2 (permalink)
YellowBoss's Avatar
Member: 1043909
Hello,
Please, be sure that you have enough free space at your HDD (at system and at current drive) due to software need a lot of free space at HDD for temporary files.
Old 06-21-2010, 17:30   #3 (permalink)
Member: 938391
The system and the current drive is the same and has more than 15GB free space. I think the prolem related to this 2 messages:
"nfi area detection...
nfi area detection finished: failed"
"write bootloader...
error: last error: 0FAE:S_FT_NFB_DOWNLOAD_BOOTLOADER_FAIL"
Old 06-24-2010, 19:14   #4 (permalink)
Member: 938391
phone still dead, Infinity team please help
Old 06-25-2010, 16:38   #5 (permalink)
YellowBoss's Avatar
Member: 1043909
Hello,
1. double check phone battery voltage. It is very important to use fully charged battery !
2. try to flash phone with original backup several time. What you see in operation log ?
3.
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
GId1 problem old_man Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 10-18-2006 15:21
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-16-1999 00:44
Page generated in 0.25325 seconds with 11 queries
