05-29-2010, 09:01 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | Flash file ORION 909 MT23C_TC71_PCB01_GPRS_MT6223P_S00.ORION_909_CY_17. BIN project-id: ORION_909_CY_17, A9C34CC6 Genral info Action: read/check information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6223, E05 Hardware version: TC71_MAIN_PCB_VER:4.0 Software version: ORION_909_CY_17" Software date: 2000.00.00 Barcode: MT012345678901234567 imei-1: 35868800******* imei-2: 35868800******* imei-3: 35868800******* Finished, time used: 7 sec Remove/Install battery now ! full info COM6 [Serial2] selected module v3.13 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:8D80:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.4BEE07D3.[MT23C_TC71_PCB01_GPRS_MT6223P_S00.ORION_909_CY_17. BIN_C64CC3A9].rpl rom info detection finished ==================== New firmware detected (v.3.13, database date: 02.05.2010): MT23C_TC71_PCB01_GPRS_MT6223P_S00.ORION_909_CY_17. BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: 4BEE07D3 rom info ver: 05 sw version: MT23C_TC71_PCB01_GPRS_MT6223P_S00.ORION_909_CY_17. BIN project-id: ORION_909_CY_17, A9C34CC6 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting ffs/eeprom structure pass 1... ........................ ffs/eeprom: detect standard location pass #1... .................................................. ...... ffs/eeprom: detect extended location pass #1... ................................................. ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: MT23C_TC71_PCB01_GPRS_MT6223P_S00.ORION_909_CY_17. BIN detecting firmware build... ................................................. firmware build: ÝORION_909_CY_17TC71_MAIN_PCB_VER-4.02010-01-1320-36 detecting product-id... .................................................. .............. done detecting languages... .......................................... language parameters detected detected languages: En Ru Fr Id Hi Cn Ar file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\M T23C_TC71_PCB01_GPRS_MT6223P_S00.ORION_909_CY_17__ system_log_4BEE07D3_C64CC3A9_20100529-132308.B0X.bin Finished, time used: 1 min 31 sec Remove/Install battery now ! BR, |
05-30-2010, 05:51 | #3 (permalink) |
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | sir u should convert into bin file then u can use it very easyly....... bcoz it has been copyied by Superdocter box..... n this file is working |
05-30-2010, 13:32 | #5 (permalink) |
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | m facing lot of problem for read flash file by infinyty........... just bcoz of that m reading with superdocter....... if u have bin converter then pls give ...... it will b very help full to me n Infinity user....... so i can post new firware in bin formate Br akashub |
06-01-2010, 09:46 | #11 (permalink) |
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | |
The Following User Says Thank You to akashub For This Useful Post: |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
how can we use *.scr files to unlock | shadow77 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-27-1999 03:13 |
