03-03-2011, 17:03 | #1 (permalink) |
No Life Poster Join Date: May 2007
Member: 503911 Status: Offline Thanks Meter: 195 | Forme Mobile invalid sim problem I had changed several IMEI in the same phone, still the IMEI changes to 1353265......... and the phone shows invalid sim. Whats the solution to this problem. |
03-04-2011, 03:52 | #3 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Change imei with the default firmware inside method. Post result. Wr. | |
03-04-2011, 09:01 | #5 (permalink) | |
Open chinese miracle- go to "Service" page-press option where written "imei #1 for dual sim/mono cpu"- there you will see last option "imei #1 (defaut imei inside firmware )". Try with that option. Wr. | |
03-04-2011, 11:41 | #6 (permalink) |
Member: 503911 Status: Offline Thanks Meter: 195 | Open chinese miracle- go to "Service" page-press option where written "imei #1 for dual sim/mono cpu"- there you will see last option "imei #1 (defaut imei inside firmware )". Try with that option. yes i done but i want to know how this process work and what is the difference between normal IMEI rebuild and default IMEI inside firmware rebuild? |
03-04-2011, 12:02 | #7 (permalink) | |
In simple words you can understand that in some mobiles imei automatically gets corrupted or changed after sometime, and this happens due to firmware inside the phone which is faulty, so with this method the firmware is modified a little to write imei and imei don't gets changed itself. Hope this much helps. Wr. | |
03-07-2011, 05:06 | #12 (permalink) |
Member: 503911 Status: Offline Thanks Meter: 195 | no after some time it is still showing invalid sim......... written original imei and changed with other imei too generated with infinity software........but still same problem after some time....what may be the reason and how to solve it? INFINITY SUPPORT pls help me out.................. |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
