Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > Chinese Miracle & PinFinder
Old 12-07-2007, 11:18   #1 (permalink)
Member: 624446
General mobile DST11 cant finilize testmode,need help please
hi.im trying to repair imei on GM Dst11.in mode1 phone cant be dedected,also cant read general info.in mode2 infinity said cant finilize test mode,of course i hold the power button long time.how to solve this problem?
ps:this problem is for second pinouts,for the first one there is no problem working very well.
COM9 [VCP8] selected
Action: imei
imei write method: mode-2
new imei: nnnnnnnnnnnnnn
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200
Initializing[6205:8B00]...
Connecting, wait...
error: can't finalize test mide
repeat operation and HOLD phone "Power" button long time !
Operation failed !
Finished, time used: 23 sec
Remove/Install battery now !
Old 12-07-2007, 19:33   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Hello,
Try to use keyboard codes to enable COM port (try different port values) and use imei repair "mode-1".
Codes: http://www.atm-box.com/index.php?id=utilities
Old 12-08-2007, 09:46   #3 (permalink)
Member: 624446
nothing happens after typing *#110*01# also factory setting codes and other codes not working.any ideas?
br
Old 12-08-2007, 18:16   #4 (permalink)
Member: 130995
Make phone backup, format ffs, try to write imei again.
Old 12-10-2007, 12:16   #5 (permalink)
Member: 624446
COM8 [Serial2] selected
Action: reset settings
19200
Connecting, wait...
Operation failed !
Finished, time used: 42 sec
Old 12-10-2007, 13:33   #6 (permalink)
Member: 624446
Device: Autodetect 6205-6227 NOR
advanced flash detection active
Action: reset
Boot...
baud autodetection active
19200
Connecting, wait...
boot step size: 000A
Release Power button now !
Boot Done
Initialize...
flash: 01227E22022201:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud...
slowest
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00800000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00700000
checking area[00000000]: 00000000-007FFFFF...
eeprom/ffs found near: 00700000
detecting eeprom/ffs size...
eeprom/ffs size: 00100000
ffs chip: 00
eeprom/ffs area: 00000000:00700000-007FFFFF
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Write Done
Finished, time used: 48 sec
after this rest operation imei1 became 13579.. as expected,but imei2 completely lost.
Old 12-10-2007, 16:41   #7 (permalink)
Member: 130995
Hello,
Try to press and hold phone "power" button more long time during imei write operation.
Old 12-11-2007, 09:26   #8 (permalink)
İboc@N's Avatar
Member: 64224
DST11 write ok .
file saved: C:\Documents and Settings\Halil ibrahim\Desktop\backup_eeprom_20071211-104458.B0E.bin
flash: 01227E22202200:29EA0000000000
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
identification#1 structure: 2nd [enhanced] generation
security area#1 Ok
security area backup saved: id.68CD4015.[MTK26_05C_X11B_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_ 16.BIN_C8860F77].rpl
identification#1 detection finished
device-id: 68CD4015
identification#1 protocol ver: 04
ver. sw1: MTK26_05C_X11B_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_ 16.BIN
ver. sw2: MAUI.05C.W06.16
ffs offset/size: 00E00000/00200000
security area#1 calculation
file saved: backup_system_log_68CD4015_MTK26_05C_X11B_PCB01_GP RS_MT6226_S01.MAUI_05C_W06_16.BIN_C8860F77_2007121 1-104555.B0X.bin
Area: Firmware
Write: Firmware
Write Done
file saved: backup_system_log_68CD4015_MTK26_05C_X11B_PCB01_GP RS_MT6226_S01.MAUI_05C_W06_16.BIN_C8860F77_2007121 1-111057.B0X.bin
Finished, time used: 1782 sec
But i cant find anyway to second pinouts
Old 12-11-2007, 12:39   #9 (permalink)
Member: 148515
hello!
if none of infinity users willl reply- you can try to fond second pinout by yourself. connecting tx and rx to all free pins in all possible combinations.
there is 12 pin connecotor with 4 pins known 3: Tx, 5: Rx, 6: Gnd, 12: Gnd. find where is battery pin also.
this will give 5 known pins in total. so only 7 unknown pins- which give total tx/rx combinations just 42.
can be tryed one by one less than in 20min
Old 12-11-2007, 16:31   #10 (permalink)
İboc@N's Avatar
Member: 64224
hello!
i will miss my mind but thank you very much infinity team. i will try again and again .
i will come
br.
ibocan
Old 12-11-2007, 17:27   #11 (permalink)
Moderator
Unknown®'s Avatar
Member: 440163
Sonork: 100.1576002
i will come
br.
ibocan
Dears canu tell me when u put double simcard and open phone type *#06# can u see 2 imei or only 1 imei?
Old 12-12-2007, 13:18   #12 (permalink)
Member: 624446
fully working fones show both imeis on screen.but if you see only 1 on screen its really big shi-t as my situation.now i have 30plus handsets with me
second pinouts:: 2:rx 4:tx
br
Old 12-12-2007, 13:24   #13 (permalink)
Member: 624446
sorry forgot to post:after formatting and repiaring first imei,sim1 working fine as always but second sim does not show signal bar.finds network but no signal bar on screen.can make calls but cant accept call.when received a call i cant accept or reject,always ringing.can recive sms and also can send.there is sometinhg wrong with dst11.i also have factory software flash files etc. but i dont know chinese and i cant use that software
Old 12-14-2007, 11:27   #14 (permalink)
Member: 624446
latest situation:i flashed the phones with this file from support (GeneralMobile-DST11_MTK26_05C_X11TK_PCB01_GPRS_MT6226_S01.MAUI_0 5C_W06_16_16m_En_Tr_w_eeprom.B0M.bin).after flashing all functions working for both simcards.but when i repair the imei,tried with both methods,sim2 cant accept calls again and no network signal.i have 2 days left to do something,then i will return the phones to customer.
br
General Mobil DST11, Tinno DX11, LT X3 pinout, firmware upgrade and write 2 IMEI Help odiseus Chinese Miracle & PinFinder 5 12-18-2008 18:02
Need Flash File for GENERAL MOBILE DST11 or LT-X3 toroslu Multi-Box 0 02-18-2008 20:52
pls help general mobile dst11 not charging ? ferdi__can Various 0 01-12-2008 20:08
URGENT i needed general mobile DST11 pinout for flash write abbaskil Chinese Miracle & PinFinder 5 12-11-2007 12:59
Page generated in 0.38261 seconds with 11 queries
