02-06-2011, 05:35 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: pakistan
Member: 334999 Status: Offline Thanks Meter: 225 | G'five 525 flash file required thanks in advance upload new version of flash file for this model COM22 [VCP1] selected module v3.26 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:45A8:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #04 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #05 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #06 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #07 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #08 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #09 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0A in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0B in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0C in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0D in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0E in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0F in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 number of flash chip/regions detected: 10/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: HEXING23D_GEMINI_ULC_07B_PCB01_GSM_MT6223_S00.MAUI _07B_W08_28_MP_V14_F1.BIN project-id: MAUI.07B.W08.28.MP.V14.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003B0000/00050000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 003B0000 flash: 7F227E220A2201:2BEA0000000000 checking area [00000000]: 00080000-003FFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 003B0000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00050000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:003B0000-003FFFFF firmware area: 00000000-003AFFFF detecting ffs/eeprom structure pass 1... ......... ffs/eeprom: detect std location pass #1... ............... ffs/eeprom: detect ext location pass #1... .............. ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: HEXING23D_GEMINI_ULC_07B_PCB01_GSM_MT6223_S00.MAUI _07B_W08_28_MP_V detecting firmware build... .............. firmware date/time: 2010-06-01 23-01 hw2: 07B_HEXING23D_GEMINI_ULC_07B done detecting product-id... ................ done detecting languages... ............. language parameters detected detected languages: En Hi Farsi Ar Finished, time used: 1 min 18 sec Remove/Install battery now ! HEXING23D_GEMINI_ULC_07B_PCB01_GSM_MT6223_S00.MAUI _07B_W08_28_MP_V14_F1_4m_En_Fr_Farsi_Ar.B0M i flash this version from support site but phone become alive but not working well this show only half scree version not compatible the support site does not have other version plz any body upload new version here thanks |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Lock 2 in nokia 51xx/61xx | Pablo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-31-1999 04:35 |
