06-30-2011, 06:46 | #1 (permalink) |
Insane Poster Join Date: Mar 2009 Location: MTM, Andhrapradesh Age: 35
Member: 992698 Status: Offline Thanks Meter: 4 | Gfive N79i format ok but no power on COM3 [VCP0] selected module v3.31 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:5803:0005 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 98000300000001:18A59F00000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98000300000001:18A59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:18A59F00000000 Finalization Done Finished, time used: 43 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
06-30-2011, 15:06 | #3 (permalink) |
Product Supporter Join Date: Nov 2010 Location: Every where
Member: 1549240 Status: Offline Thanks Meter: 1,130 | bro your phone eeprom is damage -look! search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) so only way found same working phone and read from full flash and write this dead phone |
The Following User Says Thank You to ORANGE MOB For This Useful Post: |
06-30-2011, 21:46 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! you must find original software version now, when firmware is erased there is only one way to do this: http://forum.gsmhosting.com/vbb/show....php?t=1166957 |
need a flash file tv n79i urgently | FullFlashPak | Infinity-Box | 5 | 11-21-2011 19:48 |
gfive u808 pinout | khurram_player | Chinese Models & Cloned Phones | 13 | 11-09-2010 04:49 |
n79i phonelock DEAD | FullFLASHgSMPH | Infinity-Box | 1 | 03-19-2009 12:05 |
I cant play games in my n79i | lil_pooch-357 | Chinese Models & Cloned Phones | 0 | 02-27-2009 06:44 |
N79i Pinout ?? | ~mr_Ten$ion~ | Infinity-Box | 1 | 11-01-2007 00:30 |
