Old 05-22-2010, 17:04   #1 (permalink)
Member: 383211
Thanks Meter: 131
h800 white screen after reflash"D56_HH_H200_ARAB_PCB01_GPRS_MT6225_S00.V_1 _0_6"
h800 have full signal but call is not done.i change the imei but call not work then i read full flash and eeprom and rewrite.now mobile is on and first show startuo screen after that mobile going to white screen and phone key pad and other things not work.this version inside the phon"D56_HH_H200_ARAB_PCB01_GPRS_MT6225_S00.V_1_0_ 6__fullflash_20100522-191842.B0M.bin"
and eeprom is this"D56_HH_H200_ARAB_PCB01_GPRS_MT6225_S00.V_1_0_ 6__ffs_20100522-181144.B0E.bin"and after that i download the new file from support area "D56_HH_H200_ARAB_PCB01_GPRS_MT6225_S00.V_1_0_6__E 71_16m_En_Fr_Vn_Tr_Farsi_Pt_Ar.B0M.bin"and eeprom is "D56_HH_H200_ARAB_PCB01_GPRS_MT6225_S00.V_1_0_6__E 71_ffs_01.B0E.bin"
and formatiing and writing is below plz guid me how i recover this mobile
module v3.07
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write flash
"smart write" active
write: Firmware
D56_HH_H200_ARAB_PCB01_GPRS_MT6225_S00.V_1_0_6__fu llflash_20100522-191842.B0M.bin
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
D56_HH_H200_ARAB_PCB01_GPRS_MT6225_S00.V_1_0_6__ff s_20100522-173402.B0E.bin
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:1903:000A
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01227E22202200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.D63DB014.[D56_HH_H200_ARAB_PCB01_GPRS_MT6225_S00.V_1_0_6.BIN _1D4BD5EE].rpl
rom info detection finished
device-id: D63DB014
rom info ver: 05
sw version: D56_HH_H200_ARAB_PCB01_GPRS_MT6225_S00.V_1_0_6.BIN
project-id: V_1.0.6, EED54B1D
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
startup code area #1 calculation...
startup code area #1 fixed
detecting startup code area #2...
startup code area #2 is absent
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\D 56_HH_H200_ARAB_PCB01_GPRS_MT6225_S00.V_1_0_6__sys tem_log_D63DB014_1D4BD5EE_20100522-200421.B0X.bin
Area: Firmware
Write: Firmware
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
====> Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\D 56_HH_H200_ARAB_PCB01_GPRS_MT6225_S00.V_1_0_6__sys tem_log_D63DB014_1D4BD5EE_20100522-201101.B0X.bin
Finished, time used: 7 min 41 sec
Remove/Install battery now !
Old 05-23-2010, 16:07   #2 (permalink)
Member: 383211
Thanks Meter: 131
with old read flash file the mobile is ok but when i make call the message come
"fail"and some time "unable to conect"and signol some come full and some time gone.any hope
Old 05-24-2010, 08:34   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
restore backup, and try to call 112 with SIM card removed.
if you can not make call- this is hardware problem
5110/6110 after unlocking see only network to which it was locked and ... 2M Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 07-25-2000 00:51
5110 5.24 locked all 4 locks after unlocking... MCG Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 03-07-2000 22:24
Screening indicator cxara Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-09-1999 09:13
"Menu 11"? after Net monitor Pyron Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 08-09-1999 10:07
Page generated in 0.15901 seconds with 9 queries
