Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2003 Location: africa Age: 43
Member: 22284 Status: Offline Thanks: 5
| Help chinese iphone 4 with MT6235 chip May someone help cable pinout and flash file fone chinese clone iphone 4 with Mt 6235 chip |
| | #2 (permalink) |
| herewith is the fone and i need its piout connection iPhone 4 clone A8 with dual mode support*|  Cloned In China |
| | #5 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: May 2005 Age: 36
Member: 148515 Status: Offline Thanks: 2,319
| hello! which connector has this phone? Iphone's 30pin? then you have to use same connector from infinity package. If you dont have in your set, it can be made by yourself or purchased separately |
| | #7 (permalink) |
| hello! you have to use first 24 pins of DB26 cable. they are marked 1-9, 10-18, 18-26. so it is easy to find needed 1-24. Iphone's connector has 30 pins. first type (A) cable you solder this way: DB26--------Iphone 1---------------1 2---------------2 3---------------3 4---------------4 5---------------5 6---------------6 7---------------7 8---------------8 9---------------9 11-------------11 12-------------12 13-------------13 14-------------14 15-------------15 16-------------16 17-------------17 18-------------18 19-------------19 20-------------20 21-------------21 22-------------22 23-------------23 24-------------24 |
| | #8 (permalink) |
| As you can see, in "cable A" is covered only 24 pins from 30 available in Iphones connector. Now we have to make second cable, "cable B" to cover rest of pins: DB26--------Iphone 1---------------30 2---------------29 3---------------28 4---------------27 5---------------26 6---------------25 7---------------24 8---------------23 9---------------22 11-------------21 12-------------20 13-------------19 14-------------18 15-------------17 16-------------16 17-------------15 18-------------14 19-------------13 20-------------12 21-------------11 22-------------10 23-------------9 24-------------8 |
| | #9 (permalink) |
| team Finally i got the Tx and rx inside on the main board check out the picture and am going to try and put out all my discoveries. |
| | #11 (permalink) |
| Thank i managed to format my ifone now its working and below is the log data READ GENERAL INFO Action: read/check information Model: _Autodetect MT6228-6276 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6235B, E0 Hardware version: KINGSTAR35_08B_HW Software version: MAUI.08B.W09.12.M22. Software date: 2000.00.00 Barcode: MT012345678901234567 CID: AT+READCID?ERROR Lock: AT+LOCKSTAT?ERROR imei-1: 358688000000158 Finished, time used: 3 sec Remove/Install battery now ! READ DETAILED INFO COM5 [VCP2] selected module v4.27 Device: _Autodetect MT6228-6276 NAND Checking data, wait... Action: read/check information interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8B00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0028]: 0020:00F10000001D [ST] ST01GW3B chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (460800)... done interesting cpu type found: 6235:8B00:8A00 ram test (40000000)... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 04000000/04000000 firmware size: 64Mb ffs size: 64Mb detect sec ro... error:0BF9:S_DA_HANDSET_SEC_INFO_NOT_FOUND detect custom parameters... error:0401:S_CUST_PARA_NOT_SUPPORTED detect project-id... project-id: MAUI.08B.W09.12.M22.V14 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: KINGSTAR35_08B_BOOTLOADER_V005_MT6235B_MAUI_08B_W0 9_12_M22_V14.b nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: KINGSTAR35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W09 _12_M22_V14.BIN project-id: MAUI.08B.W09.12.M22.V14, 00000000 code offset: 00000000 ffs offset/size [01]: 04000000/04000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done Disconnect... done Finished, time used: 1 min 31 sec Remove/Install battery now ! READ FIRMWARE COM5 [VCP2] selected module v4.27 Device: _Autodetect MT6228-6276 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8B00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0028]: 0020:00F10000001D [ST] ST01GW3B chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (921600)... done interesting cpu type found: 6235:8B00:8A00 ram test (40000000)... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 04000000/04000000 firmware size: 64Mb ffs size: 64Mb detect sec ro... error:0BF9:S_DA_HANDSET_SEC_INFO_NOT_FOUND detect custom parameters... error:0401:S_CUST_PARA_NOT_SUPPORTED detect project-id... project-id: MAUI.08B.W09.12.M22.V14 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: KINGSTAR35_08B_BOOTLOADER_V005_MT6235B_MAUI_08B_W0 9_12_M22_V14.b nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: KINGSTAR35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W09 _12_M22_V14.BIN project-id: MAUI.08B.W09.12.M22.V14, 00000000 code offset: 00000000 ffs offset/size [01]: 04000000/04000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done area size: 64Mb number of areas/bytes to read: 1:04000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... file saved: C:\Documents and Settings\Vin\Desktop\KINGSTAR35_08B_PCB01_GPRS_MT6 235B_S01.MAUI_08B_W09_12_ M22_V14__firmware_20120608-190145.B4M Disconnect... done Finished, time used: 60 min 42 sec Remove/Install battery now ! FORMAT FF COM5 [VCP2] selected module v4.27 Action: reset settings ("format ffs") Model: _Autodetect MT6228-6276 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8B00:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235B,E00 Date: 2000.00.00 Version: 1.0 Version: MAUI.08B.W09.12.M22.V14 Version: KINGSTAR35_08B_HW detecting structure #2... 1 2 4 5 8 9 11 12 done 88 byte(s) read imei: 35868800000015 connection Ok building list... done items total: 294 items to clear: 294 warning: wrong packet cs warning: wrong packet cs items cleared: 294 of 294 building list... done items remains: 0 Finished, time used: 1 min 29 sec Remove/Install battery now ! |
| The Following User Says Thank You to chitawira For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Sim card sleep mode problem with 6130 | ratzfatz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 05-22-2012 11:13 |
| HELP!!! BACKGROUND SCREEN LOGO | Michael Go | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-25-2011 23:56 |
| Eeprom dump lost, help needed. | CAMILO | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 11-29-2010 18:04 |
| Help with 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 05-25-2009 16:29 |
| Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 06-09-1999 17:04 |
