Old 02-01-2011, 13:28   #1 (permalink)
habibkhoso's Avatar
Member: 407739
Sonork: 100.1603554
Thanks Meter: 203
Arrow Help infinity team
i have Q.mobile china mobile imei repair problem not solve please help me log as under
COM3 [VCP0] selected
module v3.26
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: "repair imei"
imei write method: mode-3
imei write channel: imei #1 for dual sim/mono CPU
new imei: 353923776665008
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:3D03:0003
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98000300000001:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (05)
TCL-ID is absent
New firmware found (v.3.26, database date: 19.01.2011):
R206AN_LT_F15_PCB01_GPRS_MT6225_S00.R206AN_LT_E206 _F15_V02_091224.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info ver: 05
sw version: R206AN_LT_F15_PCB01_GPRS_MT6225_S00.R206AN_LT_E206 _F15_V02_091224.BIN
project-id: R206AN_LT_E206_F15_V02_091224, 00000000
code offset: 00000000
ffs offset/size [01]: 00E40000/001C0000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E40000
standard ffs/eeprom offset confirmed: 00E40000
detecting ffs/eeprom size...
ffs/eeprom size: 001C0000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E40000-00FFFFFF
firmware area: 00000000-00E3FFFF
detecting startup code area #2...
startup code area #2 is absent
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: R206AN_LT_F15_PCB01_GPRS_MT6225_S00.R206AN_LT_E206 _F15_V02_091224__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\R206AN_LT_F15_PCB 01_GPRS_MT6225_S00.R206AN_LT_E206_F15_V02_091224__ ffs_20110201-171934.B0E.bin
Backup required data Done
====> Patch required data ...
imei is not detected !
What to do:
1. Power-On phone
2. wait 20-30 sec
3. Power-Off by "Power" button, don't remove battery !
4. Repeat "imei" procedure again
If imei can't be detected:
1. make "complete" ffs/eeprom format
2. Power-On phone
3. wait 20-30 sec
4. Power-Off by "Power" button, don't remove battery !
5. Repeat "imei" procedure again
If imei can't be detected: read flash and send to support: [email protected]
Patch required data Fail
Finished, time used: 5 min 17 sec
Remove/Install battery now !
Old 02-03-2011, 03:00   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
module v3.26
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is absent
rom info ver: 05
TCL-ID is absent
ffs/eeprom chip: 00
What to do:
1. Power-On phone
2. wait 20-30 sec
2. Power-On phone
3. wait 20-30 sec
Hello,
Did you tried to follow the instruction given by software ?
Old 02-03-2011, 18:43   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
i would advise to change IMEI using mode-1 or mode-2
Old 02-06-2011, 16:56   #4 (permalink)
Member: 642050
Thanks Meter: 17
first read full flash and then change IMEI using mode-1 or mode-2
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Winlock 1.10 - Help rdmfs Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-25-1999 08:21
Page generated in 0.16462 seconds with 9 queries
