| | #1 (permalink) |
| Junior Member ![]() ![]() Join Date: Nov 2002 Location: Belarus Age: 33
Member: 17349 Status: Offline Thanks: 0
| Help me! chip size mismatch! COM21 [VCP0] selected module v2.95 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware RUSSIAN_1.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:1703:0000 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: EC240200000000:18E59F00000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: EC240200000000:18E59F00000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent ==================== New firmware detected (v.2.95, database date: 20.10.2009): E880_JJF2F11DOV_EVCOM_MT6225S00.GM_01_0_20090523.B IN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: mt62xx@gmail.com or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info protocol ver: 04 ver. sw 1: E880_JJF2F11DOV_EVCOM_MT6225S00.GM_01_0_20090523.B IN ver. sw 2: E880_JJF2F11DOV.GM.01.0, 00000000 address offset: 00000000 ffs offset/size: 01C00000/00400000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished startup code area #1 check... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: EC240200000000:18E59F00000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed Write: Firmware error: no any expected answer error: flash write error: 00000000:00002000 sec info (fast) detection... searching sec info#1... error: unexpected termination/freez: 00000000 search sec info#1 finished Write Done Finalization ... Finalization Done Finished, time used: 106 sec Remove/Install battery now ! |
| | #2 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: www.infinity-box.com
Member: 130995 Status: Offline Thanks: 5,402
| Hello, It's phone with new flash chip size that is not supported yet. We are working now to make support for this hardware type. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
